Subject: Re: Knowing if a server application is running
To: Bo Jakobsen <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Tue, 17 Jan 2017 19:49:56 +0100
There are several ways to do that.
One that I have been using (and that is similar to Mark Rivers' suggestion) is a dead-man-switch setup:
A calc/calcout record is set up as always counting down, with SCAN e.g. set to 1 second and a CALC of e.g. "VAL>0?VAL-1:0".
The LOW and LOLO fields can be used to set a yellow and red alarm.
The monitored-system (e.g. your Matlab service) resets the timer regularly by e.g writing a 10 into the calc record every couple of seconds.
Using a calcout record the OUT link can be used (with OOPT set as "Transition to Zero") to trigger something when the service is dead.
This only needs a single record (EPICS database golf hole-in-one!), doesn't have to handle counter overflow situations, allows for a yellow and red alarm, lets the client freely decide for how long it will snooze, and is quite robust with respect to slightly irregular write intervals of the monitored-system (e.g. if the service is under high load).
Cheers,
~Ralph
Re: Knowing if a server application is running Bo Jakobsen
Prev: Re: Set env var for target when building Hugo Slepicka
Next: Help regarding siemens S7 200 smart communcation Arnab Dasgupta
Prev: RE: Knowing if a server application is running Mark Rivers
Next: Re: Knowing if a server application is running Bo Jakobsen
