Is anyone running vxWorks 5.5 with a Centos 7/ RHEL 7, etc. modern NFS server?
Not me.
But one observation I made is that Centos 7 uses NFS 4.
To my understanding NFS 4 does not map the numerical user/group id
"1:1", by default, but wants to translate the remote user id into a local one
in some way.
And this is a security improvement.
In short: We needed to tweak a file called /etc/idmapd.conf.
I can dig out the details later.
Can you mount Centos 7 -> Centos 7 ?
On 19/01/17 02:00, Mark Rivers wrote:
Folks,
We are mostly running VxWorks 6.9.4 now, and with that we have no problem NFS
mounting file systems on Centos 7.
However, we have a few IOCs that still need to run VxWorks 5.5. These can
mount file systems on Centos 5 servers fine. However, on Centos 7 we see the
following:
- The NFS mount command from vxWorks succeeds with no error
- showmount on the Centos 7 system shows that the vxWorks system has
mounted the file system OK
- However, the vxWorks system cannot actually read or write any files
on the file system.
If I type the “ls” command in a valid directory I get
Cant’ open “null”.
Value=-1
The problem is not file permissions, it works fine if we are running the
identical IOC with vxWorks 6.9.4, and we have tried setting the files in that
directory to mode 755.
If so, how does one get it to work?
- RE: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Mark Rivers
- Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Mark Rivers
RE: Problem compiling StreamDevice on Visual Studio 2015 Mark Rivers
Re: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Jeong Han Lee
<2017>
2025
2026
<2017>
2025
2026
