Hi Freddie,
Thanks, that fixed the problem. The same fix is needed in 2 lines in StreamCore.cc.
Sent: Wednesday, January 18, 2017 7:31 PM
To: Mark Rivers; [email protected]
Cc: [email protected]
Subject: RE: Problem compiling StreamDevice on Visual Studio 2015
Hi Mark,
If you add some extra space around P I think it will work i.e. result.print("%" P "d,%" P "d,%" P "d:\033[37m", offs, len, cap);
The additional spaces should not change the final string concatenation result
Freddie
From: [email protected] [mailto:[email protected]] On Behalf Of Mark Rivers
Sent: 19 January 2017 01:17
To: Mark Rivers; 'Dirk Zimoch'
I just found that P is defined as:
#define P PRINTF_SIZE_T_PREFIX
The format string was changed in this commit:
commit 73cba130c32df2031a3d862ed9daf5ba00d5173b
Author: zimoch <zimoch>
Date: Thu May 16 08:28:34 2013 +0000
use ssize_t for signed index types. Win has no ssize_t, use ptrdiff_t instead.
use P instead of S as shortcut for PRINTF_SIZE_T_PREFIX because some OK already use S.
which did this:
-#define S PRINTF_SIZE_T_PREFIX
+#define P PRINTF_SIZE_T_PREFIX
- result.print("%"S"d,%"S"d,%"S"d:\033[37m", offs, len, cap);
+ result.print("%"P"d,%"P"d,%"P"d:\033[37m", offs, len, cap);
But that does not tell me how to fix it.
From: [email protected]<mailto:[email protected]> [mailto:[email protected]] On Behalf Of Mark Rivers
Sent: Wednesday, January 18, 2017 7:09 PM
To: 'Dirk Zimoch'
Cc: [email protected]<mailto:[email protected]>
Subject: Problem compiling StreamDevice on Visual Studio 2015
Hi Dirk and all,
The following line compiles OK on Visual Studio 2010, but fails on Visual Studio 2015:
This is the error:
cl -EHsc -GR -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -w44355 -w44344 -MT -TP -I. -I../O.Common -I.
-I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IJ:/epics/support/asyn-4-31/include -IJ:/epics/support/calc-3-6-1/include
-IJ:/epics/support/sscan-2-10-2/include -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include -c ../StreamBuffer.cc
StreamBuffer.cc
../StreamBuffer.cc(317): error C3688: invalid literal suffix 'P'; literal operator or literal operator template 'operator ""P' not found
H:/epics/base-3.15.5/configure/RULES_BUILD:233: recipe for target 'StreamBuffer.obj' failed
make[1]: *** [StreamBuffer.obj] Error 2
make[1]: Leaving directory 'J:/epics/support/stream/StreamDevice/src/O.windows-x64-static-vs2015'
H:/epics/base-3.15.5/configure/RULES_ARCHS:58: recipe for target 'install.windows-x64-static-vs2015' failed
make: *** [install.windows-x64-static-vs2015] Error 2
Can someone explain what the P characters in that format string do, and how to get this to compile on Visual Studio 2015?
- Re: Problem compiling StreamDevice on Visual Studio 2015 Dirk Zimoch
- Problem compiling StreamDevice on Visual Studio 2015 Mark Rivers
- RE: Problem compiling StreamDevice on Visual Studio 2015 Mark Rivers
- RE: Problem compiling StreamDevice on Visual Studio 2015 freddie.akeroyd
Re: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Torsten Bögershausen
<2017>
2025
2026
<2017>
2025
2026
