Subject: Questions about set parameters to device by using epics
Date: Thu, 26 Jan 2017 17:42:19 +0000
Below is the correct db that can read hour from the device:
record(ai, "$(RPNAM):HourVal"){
    field(DTYP,"asynInt32")
    field(INP, "@asynMask($(PORT) 68 16)MODBUS_DATA")
    field(SCAN,"Passive")
    field(FLNK, "$(RPNAM):WeekVal")
now, I want to set new hour to the device and I try to write the following db according to Analog Output Example Record from "asynDriver: Asynchronous Driver Support" manual:
record(ao, "$(RPNAM):HourValSET"){
    field(OUT, "@asyn($(PORT), 68)")
however, I failed, epics gives the following error messages:
drvModbusAsyn::writeInt32 port RD1R invalid request for Modbus function 3
Gamma:01:HourValSET devAsynInt32 process error
Could anyone give me some suggestions and thanks in advance !
Re: Questions about set parameters to device by using epics Eric Norum
Prev: Re: TEWS TIP866 serial IP Ralph Lange
Next: Re: Questions about set parameters to device by using epics Eric Norum
