Subject: Re: Questions about set parameters to device by using epics
To: lzf neu <[email protected]>
Date: Thu, 26 Jan 2017 09:57:17 -0800
You need to specify a MODBUS output function code — function code 6 to write a single holding register, function code 16 to write multiple holding registers.  Here re a couple examples
drvModbusAsynConfigure("eps1_io", "epsPLC_1", 0, 6, 16000,   1, 0, 1000, "Wago")
drvModbusAsynConfigure("eps1_ao", "epsPLC_1", 0,16, 17216,  54, 0, 1000, "Wago”)
On Jan 26, 2017, at 9:42 AM, lzf neu <[email protected]> wrote:
Below is the correct db that can read hour from the device:
record(ai, "$(RPNAM):HourVal"){
    field(DTYP,"asynInt32")
    field(INP, "@asynMask($(PORT) 68 16)MODBUS_DATA")
    field(SCAN,"Passive")
    field(FLNK, "$(RPNAM):WeekVal")
now, I want to set new hour to the device and I try to write the following db according to Analog Output Example Record from "asynDriver: Asynchronous Driver Support" manual:
record(ao, "$(RPNAM):HourValSET"){
    field(OUT, "@asyn($(PORT), 68)")
however, I failed, epics gives the following error messages:
drvModbusAsyn::writeInt32 port RD1R invalid request for Modbus function 3
Gamma:01:HourValSET devAsynInt32 process error
Could anyone give me some suggestions and thanks in advance !
答复: Questions about set parameters to device by using epics lzf neu
Prev: Questions about set parameters to device by using epics lzf neu
Next: 答复: Questions about set parameters to device by using epics lzf neu
