1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: 答复: Questions about set parameters to device by using epics
To: Eric Norum <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 27 Jan 2017 05:34:40 +0000
Firstly, thanks for your respond !
But the problem still exists, let me describe it in details.
The modbus version is R1-2(very old version).
And the contents of st.cmd file are posted in the following:
#!../../bin/linux-x86_64/modbusApp
< envPaths
dbLoadDatabase("../../dbd/modbus.dbd")
modbus_registerRecordDeviceDriver(pdbbase)
# Use the following commands for TCP/IP
#read   Device ID 2
drvAsynIPPortConfigure("AGM16-007",   "192.168.1.241:502",0,1,1)
modbusInterposeConfig("AGM16-007",  2,0,2000)
# Read 100 words (1600 bits).  Function code=3.
drvModbusAsynConfigure("RD1R",   "AGM16-007",  3, 0, 95, 0, 1130, "rpDevice")
# Write 8 words (128 bits).  Function code=16
drvModbusAsynConfigure("parawrite1", "AGM16-007", 16, 48, 8, 0, 10000, "rpDevice")
drvModbusAsynConfigure("timewrite1", "AGM16-007", 16, 64, 7, 0, 10000, "rpDevice")
dbLoadRecords("../../db/ssrfdb/RPmodbus.db","RPNAM=Gamma:01, PORT=RD1R,  paraWDPORT=parawrite1,  timeWDPORT=timewrite1")
iocInit
After running, epics displays the following errors during its initialization:
2017/01/27 12:55:21.149 drvModbusAsyn::doModbusIO port parawrite1 is disconnected
Here is the whole messages:
[rp@localhost iocTest]$ ./test.cmd
< envPaths
epicsEnvSet("ARCH","linux-x86_64")
epicsEnvSet("IOC","iocTest")
epicsEnvSet("TOP","/home/rp/epicswork/modbusR1-2")
epicsEnvSet("EPICS_BASE","/home/rp/epics/base-3.14.12.5")
epicsEnvSet("ASYN","/home/rp/epics/modules/asyn-4.9")
epicsEnvSet("GENSUB","/home/rp/epics/modules/genSubV1-6")
#read   Device ID 2
dbLoadRecords("../../db/ssrfdb/RPmodbus.db","RPNAM=DCLS:RP:Gamma:01, PORT=RD1R,  paraWDPORT=parawrite1,  timeWDPORT=timewrite1")
iocInit
Starting iocInit
## EPICS R3.14.12.5 $Date: Tue 2015-03-24 09:57:35 -0500$
## EPICS Base built Jan 25 2017
epics>
Now I can read data from device, but the problem is I cannot set parameters to device.
for example, I can read Hour from device in addr 68, but i cannot write new hour to device using the db.
This is the correct db that read Hour from device:
record(ai, "$(RPNAM):HourVal"){
    field(DTYP,"asynInt32")
    field(INP, "@asynMask($(PORT) 68 16)MODBUS_DATA")
    field(SCAN,"Passive")
    field(FLNK, "$(RPNAM):WeekVal")
This is the db that I try to write Hour to device:
record(ao, "$(RPNAM):HourValSET"){
    field(OUT, "@asyn($(PORT), 68)")
by typing the command to set new hour value '15':
caput Gamma:01:HourValSET 15
The error message displays in the following:
epics> 2017/01/27 12:56:04.314 drvModbusAsyn::writeInt32 port RD1R invalid request for Modbus function 3
2017/01/27 12:56:04.314 DCLS:RP:Gamma:01:HourValSET devAsynInt32 process error
Any suggestions and many thanks in advance !
Zhefu
发件人: Eric Norum <[email protected]>
发送时间: 2017年1月26日 17:57
收件人: lzf neu
抄送: [email protected]
主题: Re: Questions about set parameters to device by using epics
You need to specify a MODBUS output function code ― function code 6 to write a single holding register, function code 16 to write multiple holding registers.  Here re a couple examples
drvModbusAsynConfigure("eps1_io", "epsPLC_1", 0, 6, 16000,   1, 0, 1000, "Wago")
drvModbusAsynConfigure("eps1_ao", "epsPLC_1", 0,16, 17216,  54, 0, 1000, "Wago”)
On Jan 26, 2017, at 9:42 AM, lzf neu <[email protected]> wrote:
Below is the correct db that can read hour from the device:
now, I want to set new hour to the device and I try to write the following db according to Analog Output Example Record from "asynDriver: Asynchronous Driver Support" manual:
however, I failed, epics gives the following error messages:
Could anyone give me some suggestions and thanks in advance !
RE: Questions about set parameters to device by using epics Mark Rivers
Questions about set parameters to device by using epics lzf neu
Re: Questions about set parameters to device by using epics Eric Norum
Prev: Re: Questions about set parameters to device by using epics Eric Norum
Next: Re: Question about EDM Problems Bruce Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Questions about set parameters to device by using epics Mark Rivers
