Subject: Re: Question about EDM Problems
To: <[email protected]>
Date: Thu, 26 Jan 2017 22:29:27 -0800
Hi Zhefu,
Make sure you have /usr/lib64/libpng.so installed when you build edm.
If it isn't try installing it via
sudo yum install libpng-devel
Then rebuild edm.
Cheers,
- Bruce
On 01/24/2017 09:37 AM, lzf neu wrote:
I installed edm in fedora20-64 bit and the EDM version is the latest 1-12-103.
My problem is when I start edm, the interface displays normal. however, when I click help--online , and click Mouse Operations on pop up panel an error displays in Msgbox: Line 1403, Error creating object "activePngClass" and in terminal displays the following error messages:
Cannot find tag: beginObjectProperties, near line 1404
Cannot find tag: major, near line 1405
Cannot find tag: minor, near line 1406
Cannot find tag: release, near line 1407
Cannot find tag: x, near line 1408
Cannot find tag: y, near line 1409
Cannot find tag: w, near line 1410
Cannot find tag: h, near line 1411
Cannot find tag: file, near line 1412
and when i click help--online and click Editing Objects on pop up panel an error displays in Msgbox: Line 1403, Error creating object "activePngClass" and in terminal displays the following error messages:
Line 552, Error creating object "cfcf6c8a_dbeb_11d2_8a97_00104b8742df" and in terminal displays the following error messages:
Cannot find tag: beginObjectProperties, near line 553
Cannot find tag: major, near line 554
Cannot find tag: minor, near line 555
Cannot find tag: release, near line 556
Cannot find tag: x, near line 557
Cannot find tag: y, near line 558
Cannot find tag: w, near line 559
Cannot find tag: h, near line 560
Cannot find tag: file, near line 561
Could you give me some suggestions and thanks in advance!
Zhefu
Bruce Hill
Member Technical Staff
SLAC National Accelerator Lab
2575 Sand Hill Road M/S 10
Menlo Park, CA  94025
Question about EDM Problems lzf neu
Prev: 答复: Questions about set parameters to device by using epics lzf neu
Next: RE: Questions about set parameters to device by using epics Mark Rivers
Prev: Question about EDM Problems lzf neu
Next: How to read and write to character waveform using cothread Summers, Tasha
