Subject: S7plc driver - PV block receiving problems
To: [email protected]
Date: Sat, 28 Jan 2017 12:12:32 +0100
Dear All, I'm using the s7plc driver to monitor and control an RF modulator which has a PLC sending a 253byte data array and receiving a 16byte data array to/from my IOC. I did some test using the PLC server emulator (server.tcl) which was into the s7plc folder and all is nice and working right! I obtain the right process variable (PV) values I expect!!! But when I connect my IOC to the real PLC I have problems with the PVs. The PV values sometimes are correct and often wrong! Do you have any idea about the possible causes? Thanks in advance. Regards, Gianluca
Re: S7plc driver - PV block receiving problems Dirk Zimoch
Prev: Spring EPICS meeting in May at KURRI, Osaka, Japan 上窪田@KEKTokai
Next: Sequencer and Visual Studio 2015 express freddie.akeroyd
Next: Re: S7plc driver - PV block receiving problems Dirk Zimoch
