1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: S7plc driver - PV block receiving problems
To: <[email protected]>
Date: Thu, 9 Feb 2017 13:37:11 +0100
Maybe the block your PLC is sending has a different size than what you expect? Or the size is not constant?
Have a look with wireshark (or ethereal or tcpdump) what the PLC is really sending.
Dirk
On 28.01.2017 12:12, Gianluca Borgese wrote:
Dear All, I'm using the s7plc driver to monitor and control an RF
modulator which has a PLC sending a 253byte data array and receiving a
16byte data array to/from my IOC. I did some test using the PLC server
emulator (server.tcl) which was into the s7plc folder and all is nice
and working right! I obtain the right process variable (PV) values I
expect!!! But when I connect my IOC to the real PLC I have problems with
the PVs. The PV values sometimes are correct and often wrong! Do you
have any idea about the possible causes? Thanks in advance. Regards,
Gianluca
S7plc driver - PV block receiving problems Gianluca Borgese
Prev: Re: How to support a new stepper motor controller? Torsten Bögershausen
Next: Re: edm 1-12.40 on epics 3.14.12 bob.anderson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: S7plc driver - PV block receiving problems Gianluca Borgese
Next: Sequencer and Visual Studio 2015 express freddie.akeroyd
