I am trying to get a development machine on Linux RHEL 7 configured
so I can work on PyEpics scripting, and I am having some difficulties.
I have installed EPICS base 3.14.12.6 and set the PYEPICS_LIBCA,
EPICS_BASE, and EPICS_HOST_ARCH environment variables. I'm using the
Anaconda Python distribution (version 2.7 of Python) on a local install
on my machine (since it's a laptop and won't always have access to
APSshare). I installed PyEpics through conda (version 3.2.6), as
described on the PyEpics website for installation instructions. I can
perform caput and caget from the Bash shell, so I believe EPICS itself
is working correctly.
My problem is that if start an interactive Python session I can
import epics and perform caput and caget, instantiate a PV object, etc
just fine. If I try to run the exact same commands from a script, I can
still import epics without an error, but I get the error shown below
whenever I first try to do either a caget or instantiate a PV object.
I've confirmed that the runtime is looking in the same location for the
library file in both the interactive session and the script, and that
both have the same sys.path (except for the local directory being on the
path for the scripted version) and Python version. I'm really at a loss.
Traceback (most recent call last):
File
"/home/akastengren/anaconda2/lib/python2.7/site-packages/epics/ca.py",
line 215, in initialize_libca
libca = load_dll(dllname)
File "/home/akastengren/anaconda2/lib/python2.7/ctypes/__init__.py",
line 440, in LoadLibrary
return self._dlltype(name)
line 362, in __init__
self._handle = _dlopen(self._name, mode)
OSError: /home/akastengren/anaconda2/bin/../lib/libreadline.so.6:
undefined symbol: PC
File
"/home/akastengren/Python/workspace/PyEpics_Scripting/Test_install.py",
line 9, in <module>
print(epics.caget('7bmb1:m1.VAL'))
File
"/home/akastengren/anaconda2/lib/python2.7/site-packages/epics/__init__.py",
line 81, in caget
thispv = get_pv(pvname, connect=True)
File
"/home/akastengren/anaconda2/lib/python2.7/site-packages/epics/pv.py",
line 39, in get_pv
context = ca.current_context()
File
line 362, in wrapper
initialize_libca()
File
line 217, in initialize_libca
raise ChannelAccessException('loading Epics CA DLL failed: ' +
str(exc))
epics.ca.ChannelAccessException: loading Epics CA DLL failed:
/home/akastengren/anaconda2/bin/../lib/libreadline.so.6: undefined
symbol: PC
- Re: Problem installing PyEpics Pete Jemian
- Re: Problem installing PyEpics Vodopivec, Klemen
Question about CSS plot refresh lzf neu
Re: Sequencer and Visual Studio 2015 express Andrew Johnson
<2017>
2025
2026
<2017>
2025
2026
