1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem installing PyEpics
To: <[email protected]>
Date: Mon, 30 Jan 2017 12:49:03 -0600
Alan:
You reported a Python 2.7 error when loading PyEpics from a non-interactive Linux session:
>   File
> "/home/akastengren/anaconda2/lib/python2.7/site-packages/epics/ca.py",
> line 217, in initialize_libca
>     raise ChannelAccessException('loading Epics CA DLL failed: ' +
> str(exc))
> epics.ca.ChannelAccessException: loading Epics CA DLL failed:
> /home/akastengren/anaconda2/bin/../lib/libreadline.so.6: undefined
> symbol: PC
user@host ~$ nm /home/akastengren/anaconda2/lib/libreadline.so.6 | grep PC
                     U PC
The "U" means the symbol is undefined
I get the same thing (with my Anaconda installations). This is an Anaconda Python issue with the readline support. The closest web answer I can find is here:
http://stackoverflow.com/questions/29944238/importerror-when-using-rpy2-with-numpy-testing
The selected "best" answer describes three steps as the suggested fix:
1. delete __pycache__ directory (does not apply, you have Python 2.7, not Python3
2. conda install -c asmeurer readline
3. Inside the .py file, add "import readline"
Step 2, do it from the command line.  Updates readline to 6.2.5
Step 3, insert this into epics/ca.py at (or near) line 26
(/home/akastengren/anaconda2/lib/python2.7/site-packages/epics/ca.py)
Report back whether or not this helps.
Pete
Pete R. Jemian, Ph.D.                <[email protected]>
Beam line Controls and Data Acquisition, Group Leader
Advanced Photon Source,   Argonne National Laboratory
Argonne, IL  60439                   630 - 252 - 3189
   Education is the one thing for which people
      are willing to pay yet not receive.
Re: Problem installing PyEpics Matt Newville
Problem installing PyEpics Alan Kastengren
Prev: Re: Sequencer and Visual Studio 2015 express Andrew Johnson
Next: Re: Problem installing PyEpics Matt Newville
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Problem installing PyEpics Alan Kastengren
