Hi, Joey.
Independently of EPICS, I think you will find the same behavior when using Galil Tools, sending commands directly to your motor. Did you try PAA=xxxxx, BGA, PAA=yyyy, BGA, with xxxxx and yyyy corresponding to the same absolute positions in steps as the one
you tried with the motor record?
I think you will face the same problem independently of the software you use to communicate with Galil.
Cheers,
Márcio Paduan Donadio.
Hi Mark,
We have an analog based feedback loop using a potentiometer, which is as close as we can get for exact positioning. The reason why we aren't using an encoder is because there is a space constraint and we plan on implementing this system with 40 motors. We're
worried that this inconsistency with the VAL field will not work with our analog feedback and we would like to know more about it before proceeding with our project
Do you have any tips on how to proceed with this route using a potentiometer for a feedback loop?
Best,
