1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Problem compiling areaDetector-2-5
Date: Tue, 14 Feb 2017 16:00:33 +0000
Hi all,
I am trying to compile areaDetector R2-5 on Ubuntu 16.04 LTS
I git clone areaDetector, ADCore, ADSupport and ADExample and git checkout to following versions:
areaDetector R2-5
ADCore R2-5
ADSupport R1-0
ADExample R2-2
EPICS setup:
base 3.15.4
asyn-4-30
autosave-5-7-1
busy-1-6-1
calc-3-4-2-1
seq-2-23
sscan-2-10-1
Below pasties to my areaDetector/configure files:
- areaDetector folder structure   http://pastebin.com/5KmLn7Cb
- RELEASE_PATHS.local                http://pastebin.com/JbzKhrTE
- RELEASE_LIBS.local                     http://pastebin.com/Eus4L5Fi
- RELEASE_PRODS.local                http://pastebin.com/gDSyG2JT
- CONFIG_SITE.LOCAL                  http://pastebin.com/C7iumVfN
- RELEASE.local                               http://pastebin.com/a0BsWNAs
After setup above I am trying to make but compilation terminates with the error:
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DH5_NO_DEPRECATED_SYMBOLS -DH5Dopen_vers=2 -DH5Gcreate_vers=2  -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include       -I/home/eli_sw/epics/R3.15/include/compiler/gcc -I/home/eli_sw/epics/R3.15/include/os/Linux -I/home/eli_sw/epics/R3.15/include      -I/home/eli_sw/epics/support/asyn-4-30/include      -I/home/eli_sw/epics/support/areaDetector-2-5/ADCore/include                    -I/usr/local64/include  -I/usr/include/libxml2     -c ../PosPluginWrapper.cpp
In file included from ../PosPluginWrapper.cpp:8:0:
../PosPluginWrapper.h:11:25: fatal error: NDPosPlugin.h: No such file or directory
compilation terminated.
/home/eli_sw/epics/R3.15/configure/RULES_BUILD:234: recipe for target 'PosPluginWrapper.o' failed
make[4]: *** [PosPluginWrapper.o] Error 1
make[4]: Leaving directory '/home/eli_sw/epics/support_5_8_at15/areaDetector-2-5/ADCore/ADApp/pluginTests/O.linux-x86_64'
/home/eli_sw/epics/R3.15/configure/RULES_ARCHS:61: recipe for target 'install.linux-x86_64' failed
make[3]: *** [install.linux-x86_64] Error 2
make[3]: Leaving directory '/home/eli_sw/epics/support_5_8_at15/areaDetector-2-5/ADCore/ADApp/pluginTests'
/home/eli_sw/epics/R3.15/configure/RULES_DIRS:88: recipe for target 'pluginTests.install' failed
make[2]: *** [pluginTests.install] Error 2
make[2]: Leaving directory '/home/eli_sw/epics/support_5_8_at15/areaDetector-2-5/ADCore/ADApp'
/home/eli_sw/epics/R3.15/configure/RULES_DIRS:88: recipe for target 'ADApp.install' failed
make[1]: *** [ADApp.install] Error 2
make[1]: Leaving directory '/home/eli_sw/epics/support_5_8_at15/areaDetector-2-5/ADCore'
/home/eli_sw/epics/R3.15/configure/RULES_DIRS:88: recipe for target '/home/eli_sw/epics/support/areaDetector-2-5/ADCore.install' failed
make: *** [/home/eli_sw/epics/support/areaDetector-2-5/ADCore.install] Error 2
Full output you can find here: http://pastebin.com/y06WGJwX
Quick check if I have files in correct places gives me:
→ find -name "NDPosPlugin.h"
./ADCore/ADApp/pluginSrc/NDPosPlugin.h
→ find -name "PosPluginWrapper.h"
./ADCore/ADApp/pluginTests/PosPluginWrapper.h
What I am doing wrong? Is there anything else I have to setup to compile areaDetector?
Marcin
Re: Problem compiling areaDetector-2-5 Nilson Pereira
Re: Problem compiling areaDetector-2-5 Andrew Johnson
RE: Problem compiling areaDetector-2-5 Mark Rivers
Prev: RE: Logbook entry error Patard Charles-Henri
Next: Re: Problem compiling areaDetector-2-5 Nilson Pereira
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Sequencer remote pvPut CA delay (specified behavior?) Benjamin Franksen
