Subject: |
Re: Sequencer remote pvPut CA delay (specified behavior?) |
Benjamin Franksen <[email protected]> |
To: |
EPICS Techtalk <[email protected]> |
Date: |
Tue, 14 Feb 2017 14:45:19 +0100 |
On 13.02.2017 23:53, Andrew Johnson wrote:
> [...] Consider rewriting the state machine and
> using a separate when(delay(5)) state transition for the delay instead.
> I think doing this will also have an effect on your results; I don't
> know the internals of the sequencer, but I suspect it flushes the CA
> output queue at the end of each set of actions, not between individual
> action statements.
Yes. More specifically, CA output buffer always gets flushed right
before a state set thread blocks in order to wait for an event, i.e.
* before when-conditions in a state are evaluated, and
* whenever pvGet or pvPut are called with the extra SYNC flag that
makes them wait for completion.
> Your epicsThreadSleep() call appears in the middle of
> the set of actions though, so a flush at the end of the when() {} block
> won't have a chance to run until after the second pvPut() call has run
> anyway, thus causing the effect that you're seeing.
Yes, I also guess this is the reason for the behaviour Tobin sees.
Cheers
Ben
"Make it so they have to reboot after every typo." ― Scott Adams
signature.asc
Description: OpenPGP digital signature
- Sequencer remote pvPut CA delay (specified behavior?) Tobin Weber
- Re: Sequencer remote pvPut CA delay (specified behavior?) Andrew Johnson
Re: Driver for New Focus 8732 Picomotor Multi-Axis Driver Nilson Pereira
RE: Logbook entry error Patard Charles-Henri
<2017>
2025
2026
Re: Sequencer remote pvPut CA delay (specified behavior?) Tobin Weber
Problem compiling areaDetector-2-5 Marcin Lukaszewski
<2017>
2025
2026
