Subject: RE: Problem compiling areaDetector-2-5
To: Nilson Pereira <[email protected]>, Marcin Lukaszewski <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 14 Feb 2017 18:02:42 +0000
> My solution was to compile asyn from a git checkout instead if using the latest release.
What do you mean by "using the latest release".  I would like to know about any problems building areaDetector with either the master branch or any set of compatible tagged releases.
From: [email protected] [[email protected]] on behalf of Nilson Pereira [[email protected]]
Sent: Tuesday, February 14, 2017 10:39 AM
To: Marcin Lukaszewski; [email protected]
Subject: Re: Problem compiling areaDetector-2-5
Hello Marcin,
I am new to EPICS and I am not sure I will be able to help. Anyway, recently, I had a lot of trouble compiling area detector as well. The compiling errors were different than yours but maybe they have the same source.
This was my setup:
Ubuntu 16.04 LTS
EPICS Base R3.15.5
Asyn R4-31 (Head of Master on git - 19.1.2017)
Autosave R5.7.1
Busy R1.6.1
Calc R.3.61
Sequencer R2.2.4
SScan R2.10
Area Detector R2.5 with modules (Head of Master on git - 19.1.2017):
ADCore R2.5
NDDriverStdArrays R1.0
ADSupport R1.0
That is quick to try and I hope it works.
Nilson
On 14.02.2017 17:00, Marcin Lukaszewski wrote:
Hi all,
I am trying to compile areaDetector R2-5 on Ubuntu 16.04 LTS
I git clone areaDetector, ADCore, ADSupport and ADExample and git checkout to following versions:
areaDetector R2-5
ADCore R2-5
ADSupport R1-0
ADExample R2-2
EPICS setup:
base 3.15.4
asyn-4-30
autosave-5-7-1
busy-1-6-1
calc-3-4-2-1
seq-2-23
sscan-2-10-1
Below pasties to my areaDetector/configure files:
- areaDetector folder structure   http://pastebin.com/5KmLn7Cb
- RELEASE_PATHS.local                http://pastebin.com/JbzKhrTE
- RELEASE_LIBS.local                     http://pastebin.com/Eus4L5Fi
- RELEASE_PRODS.local                http://pastebin.com/gDSyG2JT
- CONFIG_SITE.LOCAL                  http://pastebin.com/C7iumVfN
- RELEASE.local                               http://pastebin.com/a0BsWNAs
After setup above I am trying to make but compilation terminates with the error:
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DH5_NO_DEPRECATED_SYMBOLS -DH5Dopen_vers=2 -DH5Gcreate_vers=2  -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include       -I/home/eli_sw/epics/R3.15/include/compiler/gcc -I/home/eli_sw/epics/R3.15/include/os/Linux -I/home/eli_sw/epics/R3.15/include      -I/home/eli_sw/epics/support/asyn-4-30/include      -I/home/eli_sw/epics/support/areaDetector-2-5/ADCore/include                    -I/usr/local64/include  -I/usr/include/libxml2     -c ../PosPluginWrapper.cpp
In file included from ../PosPluginWrapper.cpp:8:0:
../PosPluginWrapper.h:11:25: fatal error: NDPosPlugin.h: No such file or directory
compilation terminated.
/home/eli_sw/epics/R3.15/configure/RULES_BUILD:234: recipe for target 'PosPluginWrapper.o' failed
make[4]: *** [PosPluginWrapper.o] Error 1
make[4]: Leaving directory '/home/eli_sw/epics/support_5_8_at15/areaDetector-2-5/ADCore/ADApp/pluginTests/O.linux-x86_64'
/home/eli_sw/epics/R3.15/configure/RULES_ARCHS:61: recipe for target 'install.linux-x86_64' failed
make[3]: *** [install.linux-x86_64] Error 2
make[3]: Leaving directory '/home/eli_sw/epics/support_5_8_at15/areaDetector-2-5/ADCore/ADApp/pluginTests'
/home/eli_sw/epics/R3.15/configure/RULES_DIRS:88: recipe for target 'pluginTests.install' failed
make[2]: *** [pluginTests.install] Error 2
make[2]: Leaving directory '/home/eli_sw/epics/support_5_8_at15/areaDetector-2-5/ADCore/ADApp'
/home/eli_sw/epics/R3.15/configure/RULES_DIRS:88: recipe for target 'ADApp.install' failed
make[1]: *** [ADApp.install] Error 2
make[1]: Leaving directory '/home/eli_sw/epics/support_5_8_at15/areaDetector-2-5/ADCore'
/home/eli_sw/epics/R3.15/configure/RULES_DIRS:88: recipe for target '/home/eli_sw/epics/support/areaDetector-2-5/ADCore.install' failed
make: *** [/home/eli_sw/epics/support/areaDetector-2-5/ADCore.install] Error 2
Full output you can find here: http://pastebin.com/y06WGJwX
Quick check if I have files in correct places gives me:
→ find -name "NDPosPlugin.h"
./ADCore/ADApp/pluginSrc/NDPosPlugin.h
→ find -name "PosPluginWrapper.h"
./ADCore/ADApp/pluginTests/PosPluginWrapper.h
What I am doing wrong? Is there anything else I have to setup to compile areaDetector?
Marcin
Aufsichtsrat: Vorsitzender Dr. Karl Eugen Huthmacher, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Re: Problem compiling areaDetector-2-5 Nilson Pereira
Problem compiling areaDetector-2-5 Marcin Lukaszewski
Prev: sumitomo f70 compressor Pierrick Hanlet
Next: Re: sumitomo f70 compressor Lionberger, Carl A.
Prev: Re: Problem compiling areaDetector-2-5 Nilson Pereira
Next: Re: Problem compiling areaDetector-2-5 Nilson Pereira
