Subject: How access to an array value from a process variable using ca_array_get()?
To: [email protected]
Date: Wed, 15 Feb 2017 17:04:04 +0100
Title: Raquel Pérez Lázaro
Hello,
I am trying to read and write to an array value from a process variable using ca_array_get() function, but it is no clear for me how I should use this function in order to access to each element of the array and print its value.
I would appreciate an example.
Thank you,
R. Perez
Raquel Pérez Lázaro
System Engineer
IXION
Julián Camarillo, 21B – 3º
28037 Madrid, España
Phone: +34 91 440 18 33
Ph. dir: +34 91 440 18 48
FAX: +34 91 30 45 410
[email protected]
http://www.ixion.es
Re: How access to an array value from a process variable using ca_array_get()? J. Lewis Muir
Prev: RE: Problem compiling areaDetector-2-5 Marcin Lukaszewski
Next: IOC Connecting Problem Pilkyu Jung
Prev: Tech-talk archives & RSS Andrew Johnson
Next: Re: How access to an array value from a process variable using ca_array_get()? J. Lewis Muir
