On 02/15, Raquel Pérez Lázaro wrote:
> Hello,
> I am trying to read and write to an array value from a process
> variable using ca_array_get() function, but it is no clear for me
> how I should use this function in order to access to each element of
> the array and print its value.
> I would appreciate an example.
> Thank you,
> R. Perez
See the documentation for ca_array_get in the CA Reference Manual [1].
It suggests looking a "caExample.c in the example application created
by makeBaseApp.pl." You can also look at the source code for the caget
program in EPICS Base 3.14 [2] (and 3.15 [3]) which has a caget function
which uses ca_array_get_callback or ca_array_get and also iterates over
the elements of the array and prints their values.
Lewis
[1] http://www.aps.anl.gov/epics/base/R3-14/12-docs/CAref.html#ca_get
[2] http://bazaar.launchpad.net/~epics-core/epics-base/3.14/view/head:/src/catools/caget.c
[3] http://bazaar.launchpad.net/~epics-core/epics-base/3.15/view/head:/src/ca/client/tools/caget.c
- Re: How access to an array value from a process variable using ca_array_get()? Raquel Pérez Lázaro
- How access to an array value from a process variable using ca_array_get()? Raquel Pérez Lázaro
Notes on building EDM for Linux Mint 17 bob.anderson
Re: EDM compiling problems Mike Westfall
<2017>
2025
2026
<2017>
2025
2026
