Title: Raquel Pérez Lázaro
Hello,
Thank you very much for your prompt answer.
I found a really useful example in the CA Reference Manual.
R. Perez
El 16.02.2017 a las 5:48 PM, J. Lewis
Muir escribió:
On 02/15, Raquel Pérez Lázaro wrote:
Hello,
I am trying to read and write to an array value from a process
variable using ca_array_get() function, but it is no clear for me
how I should use this function in order to access to each element of
the array and print its value.
I would appreciate an example.
Thank you,
R. Perez
See the documentation for ca_array_get in the CA Reference Manual [1].
It suggests looking a "caExample.c in the example application created
by makeBaseApp.pl." You can also look at the source code for the caget
program in EPICS Base 3.14 [2] (and 3.15 [3]) which has a caget function
which uses ca_array_get_callback or ca_array_get and also iterates over
the elements of the array and prints their values.
Lewis
[1] http://www.aps.anl.gov/epics/base/R3-14/12-docs/CAref.html#ca_get
[2] http://bazaar.launchpad.net/~epics-core/epics-base/3.14/view/head:/src/catools/caget.c
[3] http://bazaar.launchpad.net/~epics-core/epics-base/3.15/view/head:/src/ca/client/tools/caget.c
Raquel Pérez Lázaro
System
Engineer
IXION
Julián
Camarillo, 21B – 3º
28037 Madrid, España
Phone: +34 91 440 18 33
Ph. dir: +34 91 440 18 48
FAX: +34 91 30 45 410
[email protected]
http://www.ixion.es
- How access to an array value from a process variable using ca_array_get()? Raquel Pérez Lázaro
- Re: How access to an array value from a process variable using ca_array_get()? J. Lewis Muir
EDM install on fedora20-64 bit system problem: "lib605432d2-f29d-11d2-973b-00104b8742df.so: cannot open shared object file: No such file or directory" lzf neu
CA.Client.Exception "Virtual circuit disconnect" source file: .../cac.pp line 1215 Raquel Pérez Lázaro
<2017>
2025
2026
IOC Connecting Problem Pilkyu Jung
<2017>
2025
2026
ANJ, 21 Dec 2017 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
