Subject: |
CA.Client.Exception "Virtual circuit disconnect" source file: .../cac.pp line 1215 |
Raquel Pérez Lázaro <[email protected]> |
To: |
[email protected] |
Date: |
Fri, 17 Feb 2017 11:57:19 +0100 |
Title: Raquel Pérez Lázaro
Hello,
I am developing a C program that runs several CA clients taks
connecting to several IOCs.
It seems that it works right when there is only one CA client
but when there are two or more clients I am getting the following
CA client exception displayed:
I have looked at line 1215 of the referenced "cac.cpp" file, you
can see in the captured picture below, but it does not get me too
much information about what is happening:
Does someone have any idea about what does it happen?, Why the
virtual circuit is disconnected?
As result of it, the second CA client program is not able any more
to connect and to monitor the process variables.
Any solution about how to solve this issue?
Thank you very much in advance,
R. Perez
Raquel Pérez Lázaro
System
Engineer
IXION
Julián
Camarillo, 21B – 3º
28037 Madrid, España
Phone: +34 91 440 18 33
Ph. dir: +34 91 440 18 48
FAX: +34 91 30 45 410
[email protected]
http://www.ixion.es
Re: How access to an array value from a process variable using ca_array_get()? Raquel Pérez Lázaro
Archive-engine compiled for linux-arm (Raspberry Pi) Miguel
<2017>
2025
2026
Re: EDM install on fedora20-64 bit system problem: "lib605432d2-f29d-11d2-973b-00104b8742df.so: cannot open shared object file: No such file or directory" Michael Davidsaver
<2017>
2025
2026
ANJ, 21 Dec 2017 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
