1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Problem compiling areaDetector-2-5
To: Marcin Lukaszewski <[email protected]>
Date: Thu, 16 Feb 2017 12:50:35 +0000
> In RELEASE.local I have a line for ADPointGrey drivers
> #ADPOINTGREY=$(AREA_DETECTOR)/ADPointGrey
> but make terminates with:
> make -C /home/eli_sw/epics/support/areaDetector-2-5/ADPointGrey install
> make[1]: *** /home/eli_sw/epics/support/areaDetector-2-5/ADPointGrey: No such file or directory.  Stop.
I suspect the problem is that you also have a RELEASE.local.$(EPICS_HOST_ARCH), e.g. RELEASE.local.linux-x86_64 which does define ADPOINTGREY.  The correct solution is to remove that file if you don't need it, or comment out ADPOINTGREY in that file.  You should not need to modify the Makefile.
Sent: Wednesday, February 15, 2017 4:28 AM
To: Mark Rivers
Cc: [email protected]
Hi Mark,
Changing WITH_XML2 to YES solved the problem.
I had to change WITH_HDF5 to YES too, to resolve the similar error (missing header file for hdf5).
The reason why I set almost everything to NO in CONFIG_SITE.local is that I wanted to start small, build a bare minimum without dependencies and then add them later. I am new to areaDetector, and I thought that would be the right approach to learning how to configure and deploy new areaDetector support.
However, there is something more which is puzzling me now.
/home/eli_sw/epics/R3.15/configure/RULES_DIRS:88: recipe for target '/home/eli_sw/epics/support/areaDetector-2-5/ADPointGrey.install' failed
make: *** [/home/eli_sw/epics/support/areaDetector-2-5/ADPointGrey.install] Error 2
To test, I tried to commenting out in Makefile
#ifdef ADPOINTGREY
#DIRS := $(DIRS) $(ADPOINTGREY)
#$(ADPOINTGREY)_DEPEND_DIRS += $(ADCORE)
#endif
and it solves the problem.
Many thanks,
Marcin
-----Original Message-----
Sent: 14 February 2017 19:12
To: Marcin Lukaszewski <[email protected]>; [email protected]
Hi Marcin,
I understand the problem.  Your CONFIG_SITE.local file defines WITH_XML2=NO.  In that case NDPosPlugin.h does not get installed in ADCore/ADApp/pluginSrc.  The pluginTests directory should not try to build the test for NDPluginPos if WITH_XML2 is not YES, but it does.  That is a bug and I have created an issue for it on Github.
Your build of ADCore is otherwise complete, so you could ignore the error.  Or you could define WITH_XML2=YES, since that library is easy to install on Linux if is not already installed.
Is there a reason that you have set WITH_XML2, WITH_TIFF, WITH_NETCDF, etc. in your CONFIG_SITE.local to NO?
From: [email protected] [[email protected]] on behalf of Marcin Lukaszewski [[email protected]]
Sent: Tuesday, February 14, 2017 10:00 AM
To: [email protected]
Subject: Problem compiling areaDetector-2-5
Hi all,
I am trying to compile areaDetector R2-5 on Ubuntu 16.04 LTS I git clone areaDetector, ADCore, ADSupport and ADExample and git checkout to following versions:
areaDetector R2-5
ADCore R2-5
ADSupport R1-0
ADExample R2-2
EPICS setup:
base 3.15.4
asyn-4-30
autosave-5-7-1
busy-1-6-1
calc-3-4-2-1
seq-2-23
sscan-2-10-1
Below pasties to my areaDetector/configure files:
- areaDetector folder structure   http://pastebin.com/5KmLn7Cb
- RELEASE_PATHS.local                http://pastebin.com/JbzKhrTE
- RELEASE_LIBS.local                     http://pastebin.com/Eus4L5Fi
- RELEASE_PRODS.local                http://pastebin.com/gDSyG2JT
- CONFIG_SITE.LOCAL                  http://pastebin.com/C7iumVfN
- RELEASE.local                               http://pastebin.com/a0BsWNAs
After setup above I am trying to make but compilation terminates with the error:
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DH5_NO_DEPRECATED_SYMBOLS -DH5Dopen_vers=2 -DH5Gcreate_vers=2  -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include       -I/home/eli_sw/epics/R3.15/include/compiler/gcc -I/home/eli_sw/epics/R3.15/include/os/Linux -I/home/eli_sw/epics/R3.15/include      -I/home/eli_sw/epics/support/asyn-4-30/include      -I/home/eli_sw/epics/support/areaDetector-2-5/ADCore/include                    -I/usr/local64/include  -I/usr/include/libxml2     -c ../PosPluginWrapper.cpp
In file included from ../PosPluginWrapper.cpp:8:0:
../PosPluginWrapper.h:11:25: fatal error: NDPosPlugin.h: No such file or directory compilation terminated.
/home/eli_sw/epics/R3.15/configure/RULES_BUILD:234: recipe for target 'PosPluginWrapper.o' failed
make[4]: *** [PosPluginWrapper.o] Error 1
make[4]: Leaving directory '/home/eli_sw/epics/support_5_8_at15/areaDetector-2-5/ADCore/ADApp/pluginTests/O.linux-x86_64'
/home/eli_sw/epics/R3.15/configure/RULES_ARCHS:61: recipe for target 'install.linux-x86_64' failed
make[3]: *** [install.linux-x86_64] Error 2
make[3]: Leaving directory '/home/eli_sw/epics/support_5_8_at15/areaDetector-2-5/ADCore/ADApp/pluginTests'
/home/eli_sw/epics/R3.15/configure/RULES_DIRS:88: recipe for target 'pluginTests.install' failed
make[2]: *** [pluginTests.install] Error 2
make[2]: Leaving directory '/home/eli_sw/epics/support_5_8_at15/areaDetector-2-5/ADCore/ADApp'
/home/eli_sw/epics/R3.15/configure/RULES_DIRS:88: recipe for target 'ADApp.install' failed
make[1]: *** [ADApp.install] Error 2
make[1]: Leaving directory '/home/eli_sw/epics/support_5_8_at15/areaDetector-2-5/ADCore'
/home/eli_sw/epics/R3.15/configure/RULES_DIRS:88: recipe for target '/home/eli_sw/epics/support/areaDetector-2-5/ADCore.install' failed
make: *** [/home/eli_sw/epics/support/areaDetector-2-5/ADCore.install] Error 2
Full output you can find here: http://pastebin.com/y06WGJwX
Quick check if I have files in correct places gives me:
→ find -name "NDPosPlugin.h"
./ADCore/ADApp/pluginSrc/NDPosPlugin.h
→ find -name "PosPluginWrapper.h"
./ADCore/ADApp/pluginTests/PosPluginWrapper.h
What I am doing wrong? Is there anything else I have to setup to compile areaDetector?
Marcin
Problem compiling areaDetector-2-5 Marcin Lukaszewski
RE: Problem compiling areaDetector-2-5 Mark Rivers
RE: Problem compiling areaDetector-2-5 Marcin Lukaszewski
Prev: RE: VAL field in Motor record Default unit Mark Clift
Next: RE: Problem compiling areaDetector-2-5 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Problem compiling areaDetector-2-5 Marcin Lukaszewski
Next: sumitomo f70 compressor Pierrick Hanlet
