Pilkyu:
In your telnet connection, you use port 5024, but in the asyn port
connection, you are attempting to use port 5025. This is quite likely
one cause of your problem.
Rod Nussbaumer
TRIUMF
Vancouver, Canada
On 02/15/2017 10:29 PM, Pilkyu Jung wrote:
Hi all,
First of all, I am trying to connect from a oscilloscope which name is
Agilent Technologies DSO-X 3052A (500 MHz 4 GSa/s) to IOC.
As you can see in the
manual(http://literature.cdn.keysight.com/litweb/pdf/75019-97073.pdf ,
http://www.keysight.com/upload/cmc_upload/All/3000_series_prog_guide.pdf),
this oscilloscope support a few ways (e.g. the IO Library, Telnet
Sockets, and using Browser Web Control) for sending SCPI.
However, When I connect to IOC, I got a problem. Until now, I just
connected only adjust IP address in st.cmd.
Like this,
drvAsynIPPortConfigure("P1",169.254.90.3:5025,0,0,0)
When I connect by telnet, it is done successfully (please check the
Screenshot...image file).
I don't know why this device can't be connected to IOC in this case.
Definitely I am done with this way before, but now I can't.
Here is my question,
1. Normally, when you connect from device to IOC, what kind of method use?
2. In my case, How can I connect to IOC?
Best Regards,
Pilkyu Jung
- Re: IOC Connecting Problem Pilkyu Jung
- IOC Connecting Problem Pilkyu Jung
RE: Problem compiling areaDetector-2-5 Mark Rivers
Notes on building EDM for Linux Mint 17 bob.anderson
<2017>
2025
2026
<2017>
2025
2026
