1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: IOC Connecting Problem
To: Florian Feldbauer <[email protected]>
Cc: [email protected]
Date: Wed, 22 Feb 2017 15:53:19 +0900
Hi Florian,
Thank you for you advice.
as you said, I missed that include dbd files and libs. It made a problem for executing IOC.
Thank you so much.
Best Regard,
Pilkyu
On 02/16/2017 03:44 PM, Florian Feldbauer wrote:
Hi Pilkyu,
in your screenshot it seems your IOC does not know the commands `drvAsynIPPortConfigure` or `asynSetTraceIOMask`.
There is also an error about setting the DTYP of a record to stream is not possible.
So I guess, the dbd file of your IOC is missing the definitions from asyn and steam.
When creating your IOC, did you include the dbd files of these modules?
The file oscApp/src/Makefile should contain something like
osc_DBD += asyn.dbd drvAsynIPPort.dbd stream.dbd
Also check, if the libraries are correctly included in this file. There should be a line like
osc_LIBS += asyn stream
I hope this helps you!
Best regards,
Florian
On 02/16/2017 07:29 AM, Pilkyu Jung wrote:
Hi all,
First of all, I am trying to connect from a oscilloscope which name is Agilent Technologies DSO-X 3052A (500 MHz 4 GSa/s) to IOC.
As you can see in the manual(http://literature.cdn.keysight.com/litweb/pdf/75019-97073.pdf , http://www.keysight.com/upload/cmc_upload/All/3000_series_prog_guide.pdf),
this oscilloscope support a few ways (e.g. the IO Library, Telnet Sockets, and using Browser Web Control) for sending SCPI.
However, When I connect to IOC, I got a problem. Until now, I just connected only adjust IP address in st.cmd.
Like this,
drvAsynIPPortConfigure("P1",169.254.90.3:5025,0,0,0)
When I connect by telnet, it is done successfully (please check the Screenshot...image file).
I don't know why this device can't be connected to IOC in this case. Definitely I am done with this way before, but now I can't.
Here is my question,
1. Normally, when you connect from device to IOC, what kind of method use?
2. In my case, How can I connect to IOC?
Best Regards,
Pilkyu Jung
| Dr. Florian Feldbauer                |
| Helmholtz-Institut Mainz             |
| Sektion SPECF                        |
| Staudinger Weg 18                    |
| D-55128 Mainz                        |
| Office: 03-149                       |
| Phone:  (+49)6131 / 39-29655         |
IOC Connecting Problem Pilkyu Jung
Re: IOC Connecting Problem Florian Feldbauer
Prev: RE: Segmentation fault at dbConvert.c in Ubuntu 32/64 bit freddie.akeroyd
Next: Re: IOC Connecting Problem Pilkyu Jung
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: IOC Connecting Problem Florian Feldbauer
Next: Re: IOC Connecting Problem Rod Nussbaumer
