Personally, I'd never consider trying to unload libCom or libca.
Neither was designed with this in mind.
For example. With libCom the errlog thread is never stopped. And libca
registers a function pointer using epicsAtExit(). So if libca is
unloaded, then running epicsExit() will fail.
There are also a number of one-time allocations which aren't cleaned up.
On 02/23/2017 03:50 AM, Carsten Winkler wrote:
> Hi there,
> when your project (e.g. LabVIEW) uses dynamic loading and unloading of
> channel access classes your main class will sometimes (at 64 bit nearly
> always) crush with a segmentation fault. The reason seems to be missing
> free() and delete functions in EPICS Base 3.14.12.6 (I'm sure this
> applies also to other EPICS Base versions).
> I wrote a tiny test case to check it and it would be great to get any
> advise to solve the issue.
> Best regards
> Carsten
> ________________________________
> Helmholtz-Zentrum Berlin für Materialien und Energie GmbH
> Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher Forschungszentren e.V.
> Aufsichtsrat: Vorsitzender Dr. Karl Eugen Huthmacher, stv. Vorsitzende Dr. Jutta Koch-Unterseher
> Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
> Sitz Berlin, AG Charlottenburg, 89 HRB 5583
> Postadresse:
> Hahn-Meitner-Platz 1
> D-14109 Berlin
> http://www.helmholtz-berlin.de
- Re: memory leak after unloading of ca.lib Ben Franksen
- memory leak after unloading of ca.lib Carsten Winkler
Re: IOC Connecting Problem Jennings, Guy
RE: RE: Re: IOC Connecting Problem Mark Rivers
<2017>
2025
2026
<2017>
2025
2026
