1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: memory leak after unloading of ca.lib
To: <[email protected]>
Date: Thu, 23 Feb 2017 21:29:18 +0100
Am 23.02.2017 um 18:26 schrieb Michael Davidsaver:
Personally, I'd never consider trying to unload libCom or libca.
Neither was designed with this in mind.
Carsten (and me) wouldn't either, it's just that Labview seems to insist
on it :-(
For example.  With libCom the errlog thread is never stopped.  And libca
registers a function pointer using epicsAtExit().  So if libca is
unloaded, then running epicsExit() will fail.
Perhaps there should be a way to unregister the epicsAtExit callback.
There are also a number of one-time allocations which aren't cleaned up.
More CA fixes needed?
Cheers
Ben
On 02/23/2017 03:50 AM, Carsten Winkler wrote:
Hi there,
when your project (e.g. LabVIEW) uses dynamic loading and unloading of
channel access classes your main class will sometimes (at 64 bit nearly
always) crush with a segmentation fault. The reason seems to be missing
free() and delete functions in EPICS Base 3.14.12.6 (I'm sure this
applies also to other EPICS Base versions).
I wrote a tiny test case to check it and it would be great to get any
advise to solve the issue.
Best regards
Carsten
Aufsichtsrat: Vorsitzender Dr. Karl Eugen Huthmacher, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Postadresse:
D-14109 Berlin
RE: memory leak after unloading of ca.lib Hill, Jeff
Re: memory leak after unloading of ca.lib Michael Davidsaver
memory leak after unloading of ca.lib Carsten Winkler
Prev: RE: memory leak after unloading of ca.lib Hill, Jeff
Next: RE: memory leak after unloading of ca.lib Hill, Jeff
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: memory leak after unloading of ca.lib Michael Davidsaver
