1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: CSS 4.3.x is not showing main help (Help Contents)
Date: Sun, 26 Feb 2017 23:17:26 +0000
Hi all
I'm trying to resolve this issue -- CSS 4.3.x doesn't run its main help from the menu: Help -> Help Contents.
And prints out the following message:
2017-02-26 22:48:06.953 SEVERE [Thread 1] org.csstudio.logging.PluginLogListener (logging) - Unhandled event loop exception
java.lang.NoClassDefFoundError: org/eclipse/equinox/http/jetty/JettyConfigurator
    at org.eclipse.help.internal.server.JettyHelpServer$StartServerThread.run(JettyHelpServer.java:78)
Caused by: java.lang.ClassNotFoundException: org.eclipse.equinox.http.jetty.JettyConfigurator cannot be found by org.eclipse.help.base_4.0.301.v20160212-1500
    at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:439)
    at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:352)
    at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:344)
    at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:160)
    at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
    ... 1 more
Regularly I use several update sites to add plugins to CSS:
http://download.controlsystemstudio.org/updates/4.3
http://download.eclipse.org/releases/mars
http://download.eclipse.org/eclipse/updates/4.5
CSS build in question is just a product build downloaded from http://controlsystemstudio.org/controlsystemstudio/current.html#
Well, org.eclipse.help.base is available from the update sites but jetty is not and it was not straightforward to find some update site.
Then I've tried update site listed on eclipse web http://download.eclipse.org/jetty/updates/jetty-bundles-9.x/ but there are other not resolved dependencies and I'm not completely sure about the right version of jetty.
So I'd rather to fix the problem in more systematic way and avoid experiments with third-party plugins and update-sites.
Is there a recommended way how to make the main Help of CSS working ?
Tomas
Re: CSS 4.3.x is not showing main help (Help Contents) Kasemir, Kay
Prev: RE: Why we want Lua on the IOC Hill, Jeff
Next: ubuntu 16.04 LTS + base3.15.5 "भावना नितिन मेढ़"
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: streamDevice protocol - accept two different valid responses Ford, Christopher
Next: Re: CSS 4.3.x is not showing main help (Help Contents) Kasemir, Kay
