Subject: Re: streamDevice protocol - accept two different valid responses
Date: Fri, 24 Feb 2017 18:08:23 +0000
Hi James,
In my experience what works well is to create an input record for each valid response format.  Use SCAN="I/O Intr" on these input records; streamDevice will automatically look for matches in parallel.
Separately, create an output record (SCAN="Passive") to send out the command.
It may be possible to create a regular _expression_ that matches all your valid formats.  Creating multiple input records turned out to be simpler in my case.
 -Chris Ford
  SLAC
From: [email protected] <[email protected]> on behalf of [email protected] <[email protected]>
Sent: Friday, February 24, 2017 8:24 AM
To: [email protected]
Subject: streamDevice protocol - accept two different valid responses
Hello,
I’m using streamDevice to handle serial data with a protocol file.
I can get two different valid responses to the same command.  Below are the protocol strings that match the two different responses:
%(\$1:C)f;L1;%(\$1:L1)f;;%(\$1:F1)f
%(\$1:C)f;;%(\$1:F1)f
What’s the easiest/most sensible way of making it accept either response?
I got it working by making one of the strings a mismatch condition but this means the record‘s severity is raised.
Thanks for any advice,
James
streamDevice protocol - accept two different valid responses James.OHea
Prev: Re: memory leak after unloading of ca.lib Carsten Winkler (HZB)
Next: Re: memory leak after unloading of ca.lib Michael Davidsaver
Prev: streamDevice protocol - accept two different valid responses James.OHea
Next: CSS 4.3.x is not showing main help (Help Contents) Mazanec Tomáš
