1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: memory leak after unloading of ca.lib
To: Michael Davidsaver <[email protected]>
Date: Fri, 24 Feb 2017 18:46:44 +0100
Hi Michael,
thanks for your help.
I wrote a stub library first, before I got the memory issues. It worked very well (since 2010) in Windows at 32-bit and 64-bit. In Linux 32-bit I could avoid the problem with delayed unloading the stub lib. Now I want to support Linux 64-bit too. But the delay trick doesn't work in that environment. That's the full story. You see, I have an old project that's running into problems under special conditions.
Do you have any other advice for me?
Best regards
Carsten
Aufsichtsrat: Vorsitzender Dr. Karl Eugen Huthmacher, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Re: memory leak after unloading of ca.lib Michael Davidsaver
memory leak after unloading of ca.lib Carsten Winkler
Re: memory leak after unloading of ca.lib Ben Franksen
RE: memory leak after unloading of ca.lib Hill, Jeff
Re: memory leak after unloading of ca.lib Carsten Winkler
Prev: Re: Why we want Lua on the IOC Kevin Peterson
Next: Re: streamDevice protocol - accept two different valid responses Ford, Christopher
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: memory leak after unloading of ca.lib Michael Davidsaver
Next: Re: memory leak after unloading of ca.lib Michael Davidsaver
