1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: memory leak after unloading of ca.lib
To: Michael Davidsaver <[email protected]>, "Hill, Jeff" <[email protected]>, Ben Franksen <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 24 Feb 2017 12:26:42 +0100
Hi there,
thank you for all response. It can be summarized as follows:
#1 libCom has the errlog thread that is never stopped.
#2 libCa registers a function pointer using epicsAtExit and if it will
fail if if libca is unloaded.
#3 There are also a number of one-time allocations which aren't cleaned up.
#4 It has something to do with the ca repeater process
#5 It has something to do with LabVIEW and it's memory management
#6 Ca context destroy doesn't clean up components in libCom and other
dependent libraries
#7 Question whether libCom will be unloaded
#8 Cleaning up with epicsExit()
My questions/answers to this points:
#1 Where/when exactly this thread is started? How can I terminate it?
#2 When will the function epicsAtExit called in my demo?
    Do you think, this function pointer leaves bad memory sections in my
case?
#3 That's what I'm looking for. Do I have any chance to resolve it?
#4 No, the caRepater is not involved. When I run my test app there is no
caRepeater process running.
#5 No, LabVIEW was the trigger only to investigate the issue. But every
program with plugin interface will have the same problem. The most
simple example is my test case.
#6 How can I do the necessary clean up?
#7 In Windows I see that Com.dll won't be unloaded. I guess it's the
same in Linux. How can I detect loaded libs at runtime?
     Will unloading of libCom solve the issue?
#8 The function epicsExit() ends with exit(status); and will terminate
calling program too. That is what I try to prevent.
Phew, it seems to be quite complicated. Hope we find a solution together.
Best regards
Carsten
Am 23.02.2017 um 23:51 schrieb Michael Davidsaver:
> On 02/23/2017 05:26 PM, Hill, Jeff wrote:
>>>> The CA client library _is_ cleaning up all of its allocations if
>>> ca_context_destroy is explicitly called, but this is of course not universal for
>>> components in libCom and or EPICS base.
>>> https://github.com/epics-base/epics-base/blob/3.14/src/ca/access.cpp#L139
>>> base/blob/3.14/src/ca/ca_client_context.cpp#L56
>> It does appear, from my perspective, to be cleaning up there but I could have another look if that’s not the case.
> It is cleaning up with epicsExit(), not ca_context_destroy().
Aufsichtsrat: Vorsitzender Dr. Karl Eugen Huthmacher, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Re: memory leak after unloading of ca.lib Michael Davidsaver
memory leak after unloading of ca.lib Carsten Winkler
Re: memory leak after unloading of ca.lib Ben Franksen
RE: memory leak after unloading of ca.lib Hill, Jeff
Prev: RE: Question about PV operation that defined in ai.template. Mark Rivers
Next: Re: memory leak after unloading of ca.lib Michael Davidsaver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: memory leak after unloading of ca.lib Michael Davidsaver
