Hi Mark,
here is the output of my IOC with asyn4-31 now. I noticed this morning that there is a new version and neede to recompile my code.
#!../../bin/linux-arm/crpc < envPaths_raspi epicsEnvSet("ARCH","linux-arm") epicsEnvSet("IOC",raspi01) epicsEnvSet("TOP","/home/fwkk_scs/Epics/app") epicsEnvSet("SNCSEQ","/home/fwkk_scs/Epics/seq-2.2.2") epicsEnvSet("EPICS_BASE","/home/fwkk_scs/Epics/base-3.14.12.5") epicsEnvSet("ASYN","/home/fwkk_scs/Epics/modules/asyn4-26") epicsEnvSet("STREAM_PROTOCOL_PATH","/home/fwkk_scs/Epics/app/protocols") epicsEnvSet("MOTOR","/home/fwkk_scs/Epics/modules/motorR6-9") epicsEnvSet("NETSNMP","/home/scs/Epics/modules/snmp") epicsEnvSet("MIBDIRS","/usr/share/mibs/ietf:/home/fwkk_scs/Epics/app/protocols") epicsEnvSet("WCR_PREF","guru WIENER-CRATE-MIB::") cd /home/fwkk_scs/Epics/app ## Register all support components dbLoadDatabase "dbd/crpc.dbd" crpc_registerRecordDeviceDriver pdbbase # Setup for HAMAMATSU power supply HamamatsuC11204_02AsynPortDriverConfigure("HAM1","/dev/ttyUSB0",0) asynSetTraceMask("HAM1",0,0x1f) asynSetTraceIOMask("HAM1",0,0x1f) dbLoadRecords "db/Hamamatsu_C11204.db" dbLoadRecords ("db/iocAdminSoft.db", "IOC=raspi01") dbLoadRecords ("db/iocAdminScanMon.db", "IOC=raspi01") ## Run this to trace the stages of iocInit #traceIocInit asynReport 1 HAM1 multiDevice:No canBlock:No autoConnect:No enabled:Yes connected:No numberConnects 0 nDevices 0 nQueued 0 blocked:No asynManagerLock:No synchronousLock:No exceptionActive:No exceptionUsers 0 exceptionNotifys 0 traceMask:0x1f traceIOMask:0x1f traceInfoMask:0x1 Port: HAM1 Timestamp: <undefined> Input EOS[0]: Output EOS[0]: Parameter list 0 Number of parameters is: 19 Parameter 0 type=asynFloat64, name=SECOND_SIDE_HIGH_TEMP_CORR_FACTOR, value is undefined Parameter 1 type=asynFloat64, name=SECOND_SIDE_LOW_TEMP_CORR_FACTOR, value is undefined Parameter 2 type=asynFloat64, name=PRIMARY_SIDE_HIGH_TEMP_CORR_FACTOR, value is undefined Parameter 3 type=asynFloat64, name=PRIMARY_SIDE_LOW_TEMP_CORR_FACTOR, value is undefined Parameter 4 type=asynFloat64, name=REFERENCE_VOLTAGE, value is undefined Parameter 5 type=asynFloat64, name=REFERENCE_TEMPERATURE, value is undefined Parameter 6 type=asynInt32, name=STATUS_READ, value is undefined Parameter 7 type=asynFloat64, name=VOLTAGE_READ, value is undefined Parameter 8 type=asynFloat64, name=CURRENT_READ, value is undefined Parameter 9 type=asynFloat64, name=TEMPERATURE_READ, value is undefined Parameter 10 type=string, name=DEVICE_NAME_READ, value is undefined Parameter 11 type=string, name=DEVICE_VERSION_READ, value is undefined Parameter 12 type=string, name=DEVICE_BUILD_DATE_READ, value is undefined Parameter 13 type=asynInt32, name=HV_OUTPUT_ON, value is undefined Parameter 14 type=asynInt32, name=HV_OUTPUT_OFF, value is undefined Parameter 15 type=asynInt32, name=RESET, value is undefined Parameter 16 type=asynInt32, name=SET_TEMP_COMP_MODE, value is undefined Parameter 17 type=asynInt32, name=MODE_WRITE, value is undefined Parameter 18 type=asynInt32, name=MODE_READ, value is undefined cd /home/fwkk_scs/Epics/app/iocBoot/ioccrpc iocInit Starting iocInit ############################################################################ ## EPICS R3.15.5 ## EPICS Base built Mar 3 2017 ############################################################################ 2017/03/16 16:37:50.614 HAM1 asynManager::queueLockPort locking port Segmentationfault
Jörn |
