Hi Jörn,
> I added a call to the base class connect function after I have connected to my device.
> The problem still persists as you can see from the output of the IOC below.
> Now the device is shown as connected.
I am not sure that I agree that the problem still persists. Previously after iocInit you got:
2017/03/16 16:37:50.614 HAM1 asynManager::queueLockPort locking port
Segmentationfault
Now you get:
2017/03/17 07:39:13.071 HAM1 asynManager::queueLockPort locking port
2017/03/17 07:39:13.081 asynPortDriver::getBounds,low=0, high=65535
2017/03/17 07:39:13.084 asynInt32SyncIO getBounds: status=0 low 0 high 65535
2017/03/17 07:39:13.087 HAM1 queueUnlockPort
2017/03/17 07:39:13.094 HAM1 asynManager::queueLockPort locking port
2017/03/17 07:39:13.094 asynPortDriver::getBounds,low=0, high=65535
2017/03/17 07:39:13.095 asynInt32SyncIO getBounds: status=0 low 0 high 65535
2017/03/17 07:39:13.096 HAM1 queueUnlockPort
2017/03/17 07:39:13.108 HAM1 asynManager::queueLockPort locking port
I don't see a segmentation fault, and I do see successful calls to queueLockPort, queueUnlockPort, and getBounds.
Please add a call to asynReport 1 at the very end of your startup script, after iocInit.
I have a more basic question. It appears you are writing an asyn driver based on asynPortDriver to talk to the Hamamatsu C11204-02. Would it be possible instead to use drvAsynSerialPort and StreamDevice? Then you only need to write a StreamDevice protocol file, not an asyn driver.
Sent: Friday, March 17, 2017 1:43 AM
To: Mark Rivers
Cc: Epics
Subject: Re: Asyn 4-30 Problem on Arm processor
Hi Mark,
I added a call to the base class connect function after I have connected to my device. The problem still persists as you can see from the output of the IOC below. Now the device is shown as connected.
Jörn
#!../../bin/linux-arm/crpc
< envPaths_raspi
epicsEnvSet("ARCH","linux-arm")
epicsEnvSet("IOC",raspi01)
epicsEnvSet("TOP","/home/fwkk_scs/Epics/app")
epicsEnvSet("SNCSEQ","/home/fwkk_scs/Epics/seq-2.2.2")
epicsEnvSet("EPICS_BASE","/home/fwkk_scs/Epics/base-3.14.12.5")
epicsEnvSet("ASYN","/home/fwkk_scs/Epics/modules/asyn4-26")
epicsEnvSet("STREAM_PROTOCOL_PATH","/home/fwkk_scs/Epics/app/protocols")
epicsEnvSet("MOTOR","/home/fwkk_scs/Epics/modules/motorR6-9")
epicsEnvSet("NETSNMP","/home/scs/Epics/modules/snmp")
epicsEnvSet("MIBDIRS","/usr/share/mibs/ietf:/home/fwkk_scs/Epics/app/protocols")
epicsEnvSet("WCR_PREF","guru WIENER-CRATE-MIB::")
cd /home/fwkk_scs/Epics/app
dbLoadDatabase "dbd/crpc.dbd"
crpc_registerRecordDeviceDriver pdbbase
# Setup for HAMAMATSU power supply
HamamatsuC11204_02AsynPortDriverConfigure("HAM1","/dev/ttyUSB0",0)
asynSetTraceMask("HAM1",0,0x1f)
asynSetTraceIOMask("HAM1",0,0x1f)
dbLoadRecords "db/Hamamatsu_C11204.db"
dbLoadRecords ("db/iocAdminSoft.db", "IOC=raspi01")
dbLoadRecords ("db/iocAdminScanMon.db", "IOC=raspi01")
## Run this to trace the stages of iocInit
#traceIocInit
asynReport 1
HAM1 multiDevice:No canBlock:No autoConnect:Yes
enabled:Yes connected:Yes numberConnects 1
nDevices 0 nQueued 0 blocked:No
asynManagerLock:No synchronousLock:No
exceptionActive:No exceptionUsers 0 exceptionNotifys 0
traceMask:0x1f traceIOMask:0x1f traceInfoMask:0x1
Port: HAM1
Timestamp: <undefined>
Input EOS[0]:
Output EOS[0]:
Parameter list 0
Number of parameters is: 19
Parameter 0 type=asynFloat64, name=SECOND_SIDE_HIGH_TEMP_CORR_FACTOR, value is undefined
Parameter 1 type=asynFloat64, name=SECOND_SIDE_LOW_TEMP_CORR_FACTOR, value is undefined
Parameter 2 type=asynFloat64, name=PRIMARY_SIDE_HIGH_TEMP_CORR_FACTOR, value is undefined
Parameter 3 type=asynFloat64, name=PRIMARY_SIDE_LOW_TEMP_CORR_FACTOR, value is undefined
Parameter 4 type=asynFloat64, name=REFERENCE_VOLTAGE, value is undefined
Parameter 5 type=asynFloat64, name=REFERENCE_TEMPERATURE, value is undefined
Parameter 6 type=asynInt32, name=STATUS_READ, value is undefined
Parameter 7 type=asynFloat64, name=VOLTAGE_READ, value is undefined
Parameter 8 type=asynFloat64, name=CURRENT_READ, value is undefined
Parameter 9 type=asynFloat64, name=TEMPERATURE_READ, value is undefined
Parameter 10 type=string, name=DEVICE_NAME_READ, value is undefined
Parameter 11 type=string, name=DEVICE_VERSION_READ, value is undefined
Parameter 12 type=string, name=DEVICE_BUILD_DATE_READ, value is undefined
Parameter 13 type=asynInt32, name=HV_OUTPUT_ON, value is undefined
Parameter 14 type=asynInt32, name=HV_OUTPUT_OFF, value is undefined
Parameter 15 type=asynInt32, name=RESET, value is undefined
Parameter 16 type=asynInt32, name=SET_TEMP_COMP_MODE, value is undefined
Parameter 17 type=asynInt32, name=MODE_WRITE, value is undefined
Parameter 18 type=asynInt32, name=MODE_READ, value is undefined
asynReport 1
Port: HAM1
Input EOS[0]:
Output EOS[0]:
Parameter list 0
cd /home/fwkk_scs/Epics/app/iocBoot/ioccrpc
iocInit
Starting iocInit
## EPICS R3.15.5
## EPICS Base built Mar 3 2017
- Re: Asyn 4-30 Problem on Arm processor Jörn Dreyer
- Asyn 4-30 Problem on Arm processor Jörn Dreyer
- RE: Asyn 4-30 Problem on Arm processor Mark Rivers
<2017>
2025
2026
<2017>
2025
2026
