Implicit in my suggestion below was that the @reconnect handler would have at least one readback operation to be able to detect the presence of the device. Also, perhaps there should be an additional parameter ‘ DelayBeforeReconnect’. The @reconnect exception handler polling interval would then be equal to (ReplyTimeout + DelayBeforeReconnect). True, but perhaps a workaround would be to specify disconnect-on-timeout — then the @reconnect handler would keep retrying at the specified reply timeout interval. Once the device became available the @reconnect handler would succeed and things would progress as desired.
I think that would be possible. I will have a look. Be aware that not all ports can provide this event. For example asyn may not know when a RS232 cable has been plugged in.
- StreamDevice exception handlers Eric Norum
- Re: StreamDevice exception handlers Dirk Zimoch
Re: StreamDevice exception handlers Eric Norum
EPICS NTNDArray ImageJ Viewer Plugin Prototype working Madden, Timothy J.
<2017>
2025
2026
<2017>
2025
2026
ANJ, 21 Dec 2017 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
