1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: EPICS NTNDArray ImageJ Viewer Plugin Prototype working
To: EPICS tech-talk <[email protected]>
Date: Tue, 21 Mar 2017 18:48:54 +0000
Folks
I have a new working ImageJ plugin for testing. it should go into AreaDetector but for now it is here:
https://github.com/argonnexraydetector/MaddenNTNDArrayJavaClient/blob/master/ImageJPlugin_NTNDArray/EPICS_NTNDA_Viewer.java
Put the java into ImageJ/plugins/EPICS_areaDetector directory.
Open the source file from Image J.
Compile and run.
it seems to work. I am not sure how to disconnect channels. Seems like calling .destroy() just makes things
not work. I suppose there is no reason to disconnect PVs anyway. If a bad PV is typed into the window, it
goes red and won't connect. If the good PV is typed in, it goes green and works. Also if IOC hosting the
arrays goes down, then back up, the plugin seems to do what it is supposed to do.
The current NTNDArray seems to have no colorMode. So that is not implemented.
Tim Madden
APS
Argonne
Prev: Re: StreamDevice exception handlers Eric Norum
Next: EPICS IOC asynMotorController error Marissa Elizabeth Kranz
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
