Subject: RE: [AsynPortDriver] "Multiple interrupt callbacks between processing" warning with multiple arrays
To: Paweł Plewiński <[email protected]>
Date: Wed, 12 Apr 2017 11:11:44 +0000
What version of asyn are you running?
If the CPU usage is that low then something else is causing the problem.
Sent: Wednesday, April 12, 2017 3:29 AM
To: Mark Rivers
Cc: [email protected]
Subject: Re: [AsynPortDriver] "Multiple interrupt callbacks between processing" warning with multiple arrays
This is an x86-64 PC based on Core 2 Duo L7400 (2x 1,5 Ghz) running in a
MTCA chassis, it's running Ubuntu Linux with kernel 4.4.0. Epics is
supplied from debian packages. The overall CPU consumption is under 15%
(usually about 5%), with about 2% for the IOC (split in several
processes).
I haven't set this variable myself so I assume it defaults to 16384.
Kind regards,
Paweł
W dniu 2017-04-11 22:01, Mark Rivers napisał(a):
> That is strange.  I run many waveform records at 10Hz or greater on
> VME system which are not fast CPUs at all.  What kind of CPU and what
> operating system is this?  What does your OS report for the CPU usage
> when you are running the IOC and the driver is sleeping for 0.5
> seconds?
> Are your waveform records forward linked to any other records which
> could be slowing things down?
> What value are you using for EPICS_CA_MAX_ARRAY_BYTES?
> Mark
> -----Original Message-----
> From: Paweł Plewiński [mailto:[email protected]]
> Sent: Tuesday, April 11, 2017 2:55 PM
> To: Mark Rivers
>> When you say "lower than 1 second" do you mean the time between
>> callbacks in your driver is less than 1 second, i.e. the usleep()
>> value is less than 1000000?
> Exactly, value below 1000000 (well, actually I can get down to 600000
> without warnings) in usleep results in warnings. Maybe it's a matter of
> speed, the machine that runs the IOC (and only the IOC, CSS is running
> on a separate computer) is not the fastest one, but our Qt application
> for this device is able to achieve update rate of ~100 ms at the same
> time drawing plot, so I think period in the range of 100-150 ms should
> be achievable here.
> Now when I added asynSetTraceMask for the "missing" channels 1-3 now it
> reports this warning for all variables.
> Kind regards,
> Paweł
> W dniu 2017-04-11 21:18, Mark Rivers napisał(a):
>> The record definition and dbpr output looks OK to me.
>> In your original post you said:
>>> The driver works, however if the update rate is lower than 1 second,
>>> strange warning appears in the console at the time of every refresh
>>> (and  that's only for one of 4 channels), namely:
>>> 2017/04/11 15:42:08.682 PIEZO:OSC-CH0-WAVEFORM
>>> devAsynFloat64Array::interruptCallbackInput
>>> \000\000\000\000\000@\205?\000\000\000\000\000\300\202?\000\000\000\000\000\000\204?\000\000\000\000\000\000\204?\000\000\000\000\000\300\202?\000\000\000\000\000\000\204?\000\000\000\000\000@\205?\000\000\000\000\000\000\204?\000\000\000\000\000\300\202?\000\000\000\000\000\000\204?
>> Is the output coming because you have enabled some asynTrace?
>>> devAsynFloat64Array::processCommon, warning, multiple interrupt
>> Are you saying that this warning message only happens on the first
>> waveform record, not on all of them?  That message is printed with
>> this code in devAsynXXXArray.h:
>>             if (pPvt->gotValue) {
>>                 asynPrint(pPvt->pasynUser, ASYN_TRACE_WARNING,
>>                     "%s %s::processCommon, "
>>                     "warning: multiple interrupt callbacks between
>> processing\n",                  \
>>                      pr->name, driverName);
>> Note that it is printed with the ASYN_TRACE_WARNING mask.  How have
>> you called asynSetTraceMask in your startup script?  Is it possible
>> you set it like this?
>> asynSetTraceMask(testAPD, 0, 255)
>> If so that would explain why you are only seeing the messages for the
>> first waveform record.  The asynTrace is specific to the asyn address,
>> and this only enables asynTrace on address 0.  To see the messages
>> from all 4 waveform records you can do this:
>> asynSetTraceMask(testAPD, -1, 255)
>> or this
>> asynSetTraceMask(testAPD, 1, 255)
>> asynSetTraceMask(testAPD, 2, 255)
>> asynSetTraceMask(testAPD, 3, 255)
>> This would not explain why you are getting the messages in the first
>> place, but it would explain why you are only seeing them for the first
>> waveform record.
>> Mark
>> Sent: Tuesday, April 11, 2017 1:55 PM
>> To: Mark Rivers
>> Hi Mark,
>> thanks for quick answer. Actually I forgot to post the record, but it
>> had SCAN set to I/O INTR, similarly to the example project. Here's the
>> record definition:
>> record(waveform, "PIEZO:OSC-CH$(CHANNEL)-WAVEFORM")
>>      field(DTYP, "asynFloat64ArrayIn")
>>      field(INP,  "@asyn($(PORT),$(ADDR),$(TIMEOUT))OSC_WAVEFORM")
>>      field(FTVL, "DOUBLE")
>>      field(NELM, "$(NPOINTS)")
>>      field(LOPR, "0")
>>      field(HOPR, "10")
>>      field(SCAN, "I/O Intr")
>> As for the commands you asked for, the results are, respectively:
>> ACKS: NO_ALARM      ACKT: YES           APST: Always        ASG:
>> ASP: (nil)          BKPT: 00            BPTR: 0xbcb3e0      BUSY: 0
>> DESC:               DISA: 0             DISP: 0             DISS:
>> NO_ALARM
>> DISV: 1             DPVT: 0xc05690      DSET: 0x7f2dbdcea9a0
>> DTYP: asynFloat64ArrayIn                EGU:                EVNT: 0
>> FLNK:CONSTANT 0     FTVL: DOUBLE        HASH: 0             HOPR: 10
>> INP:INST_IO @asyn(testAPD,0,1)OSC_WAVEFORM                  LCNT: 0
>> LOPR: 0             LSET: 0xc07f40
>> MLIS: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
>> MLOK: b0 b3 bc 00 00 00 00 00           MPST: Always
>> NAME: PIEZO:OSC-CH0-WAVEFORM            NELM: 1000          NORD: 1000
>> NSEV: NO_ALARM      NSTA: NO_ALARM      PACT: 0             PHAS: 0
>> PINI: NO            PPN: (nil)          PPNR: (nil)         PREC: 0
>> PRIO: LOW           PROC: 0             PUTF: 0             RARM: 0
>> RDES: 0xb86470      RPRO: 0             RSET: 0x7f2dbda73340
>> SCAN: I/O Intr      SDIS:CONSTANT       SEVR: NO_ALARM
>> SIML:CONSTANT
>> SIMM: NO            SIMS: NO_ALARM      SIOL:CONSTANT       SPVT:
>> 0xc135e0
>> STAT: NO_ALARM      TIME: 2017-04-11 20:53:12.153366126     TPRO: 0
>> TSE: 0              TSEL:CONSTANT       UDF: 0              VAL: (nil)
>> ASP: (nil)          BKPT: 00            BPTR: 0xbcd3a0      BUSY: 0
>> NO_ALARM
>> DISV: 1             DPVT: 0xc05be0      DSET: 0x7f2dbdcea9a0
>> INP:INST_IO @asyn(testAPD,1,1)OSC_WAVEFORM                  LCNT: 0
>> LOPR: 0             LSET: 0xc07f60
>> MLOK: 70 d3 bc 00 00 00 00 00           MPST: Always
>> NAME: PIEZO:OSC-CH1-WAVEFORM            NELM: 1000          NORD: 1000
>> SIML:CONSTANT
>> 0xc138f0
>> STAT: NO_ALARM      TIME: 2017-04-11 20:53:29.910249080     TPRO: 0
>> ASP: (nil)          BKPT: 00            BPTR: 0xbcf360      BUSY: 0
>> NO_ALARM
>> DISV: 1             DPVT: 0xc060e0      DSET: 0x7f2dbdcea9a0
>> INP:INST_IO @asyn(testAPD,2,1)OSC_WAVEFORM                  LCNT: 0
>> LOPR: 0             LSET: 0xc07f80
>> MLOK: 30 f3 bc 00 00 00 00 00           MPST: Always
>> NAME: PIEZO:OSC-CH2-WAVEFORM            NELM: 1000          NORD: 1000
>> SIML:CONSTANT
>> 0xc13c00
>> STAT: NO_ALARM      TIME: 2017-04-11 20:54:17.907769453     TPRO: 0
>> ASP: (nil)          BKPT: 00            BPTR: 0xa7b540      BUSY: 0
>> NO_ALARM
>> DISV: 1             DPVT: 0xab0810      DSET: 0x7efec944b9a0
>> INP:INST_IO @asyn(testAPD,3,1)OSC_WAVEFORM                  LCNT: 0
>> LOPR: 0             LSET: 0xab21d0
>> MLOK: 10 b5 a7 00 00 00 00 00           MPST: Always
>> NAME: PIEZO:OSC-CH3-WAVEFORM            NELM: 1000          NORD: 1000
>> RDES: 0xa30650      RPRO: 0             RSET: 0x7efec91d4340
>> SIML:CONSTANT
>> 0xabe140
>> STAT: NO_ALARM      TIME: 2017-04-11 20:52:33.970326348     TPRO: 0
>> Best regards,
>> Paweł
>> W dniu 2017-04-11 18:24, Mark Rivers napisał(a):
>>> Hi Pawel,
>>> What is the SCAN field of your waveform record?  I suspect it is
>>> probably periodic ("1 second", etc.).  For this application you
>>> should
>>> set it to SCAN="I/O Intr".  Then the waveform record will process
>>> each
>>> time your driver does a callback to device support.  If the record is
>>> periodically processing at 1 second and your driver is doing
>>> callbacks
>>> faster than 1 Hz then you will see the error you report.
>>> Mark
>>> From: [email protected]
>>> [mailto:[email protected]] On Behalf Of Pawel Plewinski
>>> Sent: Tuesday, April 11, 2017 8:49 AM
>>> To: [email protected]
>>> Subject: [AsynPortDriver] "Multiple interrupt callbacks between
>>> Hi,
>>> I've recently written asyn-based device support for a custom device
>>> communicating over PCIe. One of its functions is to periodically
>>> retrieve 4 waveforms from 4 channels, which is done in a separate
>>> thread, from which the callback function is called to notify asyn
>>> about
>>> change. I heavily based the code on the AsynPortDriver example.
>>> (and
>>> The parameters passed to the top level constructor are
>>>     : asynPortDriver(portName,
>>>                      4, /* maxAddr */
>>>                      (int)NUM_SCOPE_PARAMS,
>>>                      asynInt32Mask | asynFloat64Mask |
>>> asynFloat64ArrayMask | asynEnumMask | asynDrvUserMask, /* Interface
>>> mask
>>> asynFloat64ArrayMask | asynEnumMask,  /* Interrupt mask */
>>>                      ASYN_MULTIDEVICE, /* asynFlags.  This driver
>>> does
>>> not block and it is not multi-device, so flag is 0 */
>>>                      1, /* Autoconnect */
>>>                      0, /* Default priority */
>>>                      0) /* Default stack size*/
>>> The readback thread code:
>>> void piezoPortDriver::readbackTask(void)
>>>     while (1) {
>>>             bool stopped = false;
>>>             lock();
>>>             auto new_data = osc->fetch_data(vtim, vdat);
>>>             unlock();
>>>             if (!stopped)
>>>                 lock();
>>>                 this->osc_update_trigger();
>>>                 unlock();
>>>          callParamCallbacks();
>>>          for (int i = 0; i < 4; i++){
>>>            doCallbacksFloat64Array(vdat[i].data(), vdat[i].size(),
>>> P_OscWaveform, i);
>>>          usleep(100000);
>>> The fetch_data method reads four 1000-element double vectors from
>>> PCIe.
>>> Could you give me some suggestions what may be wrong?
>>> Regards,
>>> Paweł Plewiński
>>> Department of Microelectronics and Computer Science
>>> Lodz University of Technology
[AsynPortDriver] "Multiple interrupt callbacks between processing" warning with multiple arrays Paweł Plewiński
RE: [AsynPortDriver] "Multiple interrupt callbacks between processing" warning with multiple arrays Mark Rivers
Re: [AsynPortDriver] "Multiple interrupt callbacks between processing" warning with multiple arrays Paweł Plewiński
Prev: Re: CA client within Asyn Benoit RAT
Next: RE: Writing Area Detector Monitor Iain Marcuson
Prev: Re: [AsynPortDriver] "Multiple interrupt callbacks between processing" warning with multiple arrays Paweł Plewiński
Next: Writing Area Detector Monitor Iain Marcuson
