>The problem is that i would not like it to be instantiated as an
>undefined pv.
If I understand correctly, I think all you need is the PINI field set true ...
record(stringin , "$(user):ExperienceString"){
info(autosaveFields, "VAL") #autosave
field(VAL, "no experience")
field(PINI,"YES")
field(DESC, "anotar estados da experiencia")
Ned
From: [email protected] [[email protected]] on behalf of Miguel [[email protected]]
Sent: Friday, April 14, 2017 11:18 AM
To: [email protected]
Subject: Init pv properly
Hello,
I would like to create a Pv that at the epics start up does not have any
specific value or one forced by me.
For example i would like to have a string that its initial state is not
really important (no experience). Like:
Where ill change this afterwrds manually when it will be important.
undefined pv.
Changing the VAL is the most appropriated method? I tought about changin
UDF to 0 but did not work.
The same for a integer pv. Wich kind of pv should i use and how should i
instantiate it?
Thanks a lot,
MiguelB
- Re: Init pv properly Miguel
- Init pv properly Miguel
<2017>
2025
2026
<2017>
2025
2026
ANJ, 21 Dec 2017 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
