1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Init pv properly
To: "Arnold, Ned D." <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 14 Apr 2017 17:30:47 +0100
Yes you are right. I was going to say that that would not help me because i have the autosave and the PINI would overwrite it, but that actually not true. I got this wrong the first time I did it.
Thanks 4 the help.
By the way, what kind of record should i be using for a decimal value that is not either a ai, ao or calc. I mean, it is a value that is only changed by the user manually.Like a setpoint or something similar.
On 14-04-2017 17:24, Arnold, Ned D. wrote:
>The problem is that i would not like it to be instantiated as an
>undefined pv.
If I understand correctly, I think all you need is the PINI field set true  ...
record(stringin , "$(user):ExperienceString"){
info(autosaveFields, "VAL") #autosave
field(VAL, "no experience")
field(PINI,"YES")
field(DESC, "anotar estados da experiencia")
   Ned
From: [email protected] [[email protected]] on behalf of Miguel [[email protected]]
Sent: Friday, April 14, 2017 11:18 AM
To: [email protected]
Subject: Init pv properly
Hello,
I would like to create a Pv that at the epics start up does not have any
specific value or one forced by me.
For example i would like to have a string that its initial state is not
really important (no experience). Like:
Where ill change this afterwrds manually when it will be important.
undefined pv.
Changing the VAL is the most appropriated method? I tought about changin
UDF to 0 but did not work.
The same for a integer pv. Wich kind of pv should i use and how should i
instantiate it?
Thanks a lot,
MiguelB
RE: Init pv properly Arnold, Ned D.
Init pv properly Miguel
Prev: RE: Init pv properly Arnold, Ned D.
Next: RE: Init pv properly Mooney, Tim M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Init pv properly Arnold, Ned D.
