Subject: RE: Init pv properly
To: Miguel <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 14 Apr 2017 16:32:51 +0000
If the record mustn't be processed, but you want it not to be in an alarm state, you can add the following field specifications:
  field(STAT, "0")
  field(SEVR, "0")
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
From: [email protected] [[email protected]] on behalf of Miguel [[email protected]]
Sent: Friday, April 14, 2017 11:18 AM
To: [email protected]
Subject: Init pv properly
Hello,
I would like to create a Pv that at the epics start up does not have any
specific value  or one forced by me.
For example i would like to have a string that its initial state is not
really important (no experience). Like:
record(stringin , "$(user):ExperienceString"){
     info(autosaveFields, "VAL")        #autosave
     field(VAL, "no experience")
     field(DESC, "anotar estados da experiencia")
Where ill change this afterwrds manually when it will be important.
The problem is that i would not like it to be instantiated as an
undefined  pv.
Changing the VAL is the most appropriated method? I tought about changin
UDF to 0 but did not work.
The same for a integer pv. Wich kind of pv should i use and how should i
instantiate it?
Thanks a lot,
MiguelB
Init pv properly Miguel
Prev: Re: Init pv properly Miguel
Next: Re: Archiver Appliance established multiple CA connections for one channel Michael Davidsaver
Next: Fwd: CSS binary color text Miguel
