1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Init pv properly
To: Andrew Johnson <[email protected]>, "Arnold, Ned D." <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 14 Apr 2017 18:00:17 +0100
Thanks that is exactly what i am going to do ( i was doing that already but now i will use INP field instead of VAL and add the DTYP as well)
On 14-04-2017 17:56, Andrew Johnson wrote:
On 04/14/2017 11:49 AM, Miguel wrote:
It does work yes. Just wondering if there was a more suitable one. Thanks
For a numeric parameter that can be set by the user, the best record
type to use is usually the ao record (or the longout for integers); you
can then use the DRHV/DRVL fields to limit the range of values that will
be accepted, and/or the IVOA field along with alarm limits to control
what happens for bad values:
https://wiki-ext.aps.anl.gov/epics/index.php/RRM_3-14_Common#Invalid_Alarm_Output_Action
- Andrew
Init pv properly Miguel
RE: Init pv properly Arnold, Ned D.
Re: Init pv properly Miguel
Re: Init pv properly Andrew Johnson
Prev: Re: Init pv properly Andrew Johnson
Next: RE: Writing Area Detector Monitor Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Init pv properly Mooney, Tim M.
