1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CAS: partial (damaged?) UDP msg
To: Zhang Yuliang <[email protected]>, tech-talk <[email protected]>
Date: Sun, 16 Apr 2017 10:46:58 -0400
On 04/16/2017 10:39 AM, Michael Davidsaver wrote:
>> CAS: request from 10.1.204.140:54439 => CAS: Missaligned protocol rejected
>> CAS: Request from 10.1.204.140:54439 => cmmd=0 cid=0x4143435f type=0 count=3100 postsize=3100
>> CAS: Request from 10.1.204.140:54439 =>   available=0x4c524254 	N=3 paddr=(nil)
> The offending header was:
>> 00000c1c 00000c1c 4143435f 4c524254
Also the N=3 indicates that other this is the 4th message in the UDP
packet and the the previous 3 were considered valid.
The seems like a client is not constructing UDP packets properly.
Re: CAS: partial (damaged?) UDP msg Michael Davidsaver
CAS: partial (damaged?) UDP msg Zhang Yuliang
Prev: Re: CAS: partial (damaged?) UDP msg Michael Davidsaver
Next: Re: CAS: partial (damaged?) UDP msg Shen, Guobao
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: CAS: partial (damaged?) UDP msg Michael Davidsaver
