Subject: 答复: Question about string operation in epics db ?
To: Iain Marcuson <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 17 Apr 2017 13:44:28 +0000
Thanks, it's a good idea. howeve, I want to change the PV value in db record, then display the PV in CSS rather than make the operation  in CSS. Any other idea? Thanks.
发件人: Iain Marcuson <[email protected]>
发送时间: 2017年4月17日 13:20
收件人: lzf neu; [email protected]
主题: RE: Question about string operation in epics db ?
Have you tried using a Rule to change the foreground color?  I can change the foreground to something other than its default using a rule, but I cannot figure out the semantics of specifying a specific value to change on.
Iain.
From: [email protected] [mailto:[email protected]] On Behalf Of lzf neu
Sent: Monday, April 17, 2017 9:16 AM
To: [email protected]
Subject: Question about string operation in epics db ?
I have a question to consult you.
PV name: "Global-second2_dword" is used to display 60 seconds countdown from PLC.
If the seconds countdown is less than 10, it displays a single digital in terminal. Now I want to add zero in the left of the single digital. eg.09,08,07,06,05,04,03,02,01,00.
Maybe string operation may solve the problem. I have tried  "scalcout" record, but epics displays the error message:
Record XXX is of unknown type "scalcout" and I have no idea how to write the db.
I have post the record in the following lines:
record(ai, "Global-Second")
    field(DTYP, "s7nodave")
    field(INP, "@s7_300 (PG=.2s) MW60")
    field(SCAN, "I/O Intr")
    field(FLNK, "Global-Second2_dword")
record(calc, "Global-Second2_dword")
        field(INPA, "Global-Second.VAL")
        field(CALC, "A/10")
Any help will be apprecieated and thanks in advance!
Zhefu
Question about string operation in epics db ? lzf neu
RE: Question about string operation in epics db ? Iain Marcuson
Prev: RE: Question about string operation in epics db ? Iain Marcuson
Next: RE: CSS binary color text Iain Marcuson
Next: RE: Question about string operation in epics db ? Mooney, Tim M.
