Subject: RE: Question about string operation in epics db ?
To: lzf neu <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 17 Apr 2017 14:55:44 +0000
Hi Zhefu,
The scalcout record is not in EPICS base; it's in the calc module:
https://github.com/epics-modules/calc
If you want to use it, you must build the calc module separately from EPICS base,
as described in calc/documentation/calcDocs.html
A database-fragment that does what you've described might look like this:
record(scalcout, "recname") {
    field(INPA, "<link to number-of-seconds PV>")
    field(CALC, "printf('%02d', a)")
If you're using EPICS base 3.15, you can use the printf record.
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
From: [email protected] [[email protected]] on behalf of lzf neu [[email protected]]
Sent: Monday, April 17, 2017 8:15 AM
To: [email protected]
Subject: Question about string operation in epics db ?
I have a question to consult you.
PV name: "Global-second2_dword" is used to display 60 seconds countdown from PLC.
If the seconds countdown is less than 10, it displays a single digital in terminal. Now I want to add zero in the left of the single digital. eg.09,08,07,06,05,04,03,02,01,00.
Maybe string operation may solve the problem. I have tried  "scalcout" record, but epics displays the error message:
Record XXX is of unknown type "scalcout" and I have no idea how to write the db.
I have post the record in the following lines:
record(ai, "Global-Second")
    field(DTYP, "s7nodave")
    field(INP, "@s7_300 (PG=.2s) MW60")
    field(SCAN, "I/O Intr")
    field(FLNK, "Global-Second2_dword")
record(calc, "Global-Second2_dword")
        field(INPA, "Global-Second.VAL")
        field(CALC, "A/10")
Any help will be apprecieated and thanks in advance!
Zhefu
Question about build calc module to use scalcout record lzf neu
Question about string operation in epics db ? lzf neu
Prev: Re: CSS binary color text Hartman, Steven M.
Next: EPICS support for Solaris (on SPARC or x86)? Andrew Johnson
Prev: 答复: Question about string operation in epics db ? lzf neu
Next: Question about build calc module to use scalcout record lzf neu
