Subject: Re: 3.16.1: asynSetTraceMask and asynSetTraceIOMask
To: <[email protected]>
Date: Tue, 18 Apr 2017 09:50:18 +0100
Dear all,
Thanks for the help.
I am attempting to switch to 3.16 because I thought I read somewhere, though I don't recall where, that the string length limit is eliminated here. With asyn/streamdevice, I'm attempting to read a long string from an Oxford Instruments Mercury iTC. Is
the limit removed in 3.15?
In answer to Mark's original question, with 3.16.0.1 (which I'll not use, but it may be useful information), I did not see any asyn commands listed when I typed help at the iocsh prompt, and I did include asyn.dbd.
Thanks again,
Pierrick
On 04/14/2017 03:16 PM, J. Lewis Muir wrote:
On 04/14, J. Lewis Muir wrote:
Pierrick, and if you're not clear on the intent behind the versioning
(like I once was), this email is particularly enlightening:
   http://www.aps.anl.gov/epics/tech-talk/2016/msg01398.php
Quoting Ralph Lange from that email:
   All releases having a 0 as third part of the release number
   (e.g. 3.15.0, 3.16.0.1) are explicitly deemed "not for production
   use".
Andrew, come to think of it, it would be really great to include a
paragraph about the versioning and its meaning, the available series
and their meanings, and which series is recommended for which people
under which conditions--something like the above and in the referenced
Tech-Talk email--in a paragraph in the Versions section at:
   http://www.aps.anl.gov/epics/base/index.php
What do you think?
Lewis
"Whether you think you can or think you can't, either way, you are correct" -- Henry Ford
_______________________________________________________________
Pierrick Hanlet
IIT/Fermilab
+44-(0)1235-44-5550 (RAL)
+1-630-840-5555 (FNAL)
+1-312-567-5745 (IIT)
+1-630-888-0185/+44-(0)79-48-860-197 (US/UK mobile)
Re: 3.16.1: asynSetTraceMask and asynSetTraceIOMask Michael Davidsaver
3.16.1: asynSetTraceMask and asynSetTraceIOMask Pierrick Hanlet
Re: 3.16.1: asynSetTraceMask and asynSetTraceIOMask Andrew Johnson
Re: 3.16.1: asynSetTraceMask and asynSetTraceIOMask J. Lewis Muir
Prev: areaDetector to Apache Kafka plugin and Apache Kafka to areaDetector driver Jonas Nilsson
Next: Re: Asyn timeout Hinko Kocevar
Prev: Re: 3.16.1: asynSetTraceMask and asynSetTraceIOMask Andrew Johnson
Next: Re: 3.16.1: asynSetTraceMask and asynSetTraceIOMask Michael Davidsaver
