1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: 3.16.1: asynSetTraceMask and asynSetTraceIOMask
To: [email protected], Pierrick Hanlet <[email protected]>
Date: Tue, 18 Apr 2017 07:19:50 -0400
On 04/18/2017 04:50 AM, Pierrick Hanlet wrote:
> Dear all,
> Thanks for the help.
> I am attempting to switch to 3.16 because I thought I read somewhere,
> though I don't recall where, that the string length limit
> is eliminated here.
The limitation you may be thinking of is on the length of link fields
(eg. INP/OUT).  In the 3.16 series these can be arbitrarily long.
The length of a DBF_STRING field remains unchanged.  The usual
workaround is to use a waveformRecord with FTVL=CHAR.  This isn't new to
3.16 though.
>  With asyn/streamdevice, I'm attempting to read a
> long string from an Oxford Instruments Mercury iTC.  Is
> the limit removed in 3.15?
> In answer to Mark's original question, with 3.16.0.1 (which I'll not
> use, but it may be useful information), I did not see
> any asyn commands listed when I typed help at the iocsh prompt, and I
> did include asyn.dbd.
Are you able to test with the latest 3.16.x code from VCS?  I've been
testing this with asyn/areadetector for some time now and haven't seen
this behavior.
Can you verify that the final .dbd file contains the line:
> registrar(asynRegister)
3.16.1: asynSetTraceMask and asynSetTraceIOMask Pierrick Hanlet
Re: 3.16.1: asynSetTraceMask and asynSetTraceIOMask Andrew Johnson
Re: 3.16.1: asynSetTraceMask and asynSetTraceIOMask J. Lewis Muir
Re: 3.16.1: asynSetTraceMask and asynSetTraceIOMask Pierrick Hanlet
Prev: Re: Fwd: CSS binary color text Luca Cavalli
Next: Re: Archiver Appliance established multiple CA connections for one channel Wang, Lin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: 3.16.1: asynSetTraceMask and asynSetTraceIOMask Pierrick Hanlet
Next: ICALEPCS 2017 abstract submission deadline James Rezende Piton
