Subject: Re: runtime problem
To: Pierrick Hanlet <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 19 Apr 2017 10:50:28 -0400
Hi Pierrick,
> concludes with Michael Davidsaver stating:
> "*I've hit this it was because I accidentally loaded a .dbd from an
> older version of epics base*"
> However, I don't believe that's what I've done wrong.
I've not seen this assertion fail in any other circumstance since I
added it.
The specific condition being detected is that the number of fields in
some recordtype is different between the runtime and buildtime definitions.
I suspect that, without intending to, you have epics modules in the
standard search paths (eg. /usr/local), or in your environment (eg. PATH
or LIBRARY_PATH), or perhaps some includes in configure/RELEASE.
I would suggest that you retry your builds in a completely clean
environment.  checkout/untar source into a fresh OS install (a VM would
be a quick way to do this).
Michael
On 04/19/2017 09:31 AM, Pierrick Hanlet wrote:
> Hello,
> I'm using base 3.14.12.3 with SL7.3. I've recently attempted to use
> another version of base, so I'm switching back
> to something that previously worked for me.  When reverting to the older
> version, I first rebuilt all of my support
> modules (asyn, etc.) using the 3.14.12.3 base. Then I rebuilt my IOC.  I
> got no errors, however, when I run, I get:
> *dbLoadDatabase "dbd/TestCryo.dbd"**
> **TestCryo_registerRecordDeviceDriver pdbbase**
> **A call to 'assert(prt->no_fields == 122)'**
> **    by thread '_main_' failed in ../O.Common/asynRecord.h line 426.**
> **EPICS Release EPICS R3.14.12.3 $Date: Mon 2012-12-17 14:11:47 -0600$.**
> **Local time is 2017-04-19 13:30:21.552933101 BST**
> **Please E-mail this message to the author or to [email protected]**
> **Calling epicsThreadSuspendSelf()**
> I followed the tech-talk thread
> http://www.aps.anl.gov/epics/tech-talk/2016/msg01042.php which
> Thanks,
> Pierrick
> "Whether you think you can or think you can't, either way, you are correct" -- Henry Ford
> _______________________________________________________________
> Pierrick Hanlet
> IIT/Fermilab
> +44-(0)1235-44-5550 (RAL)
> +1-630-840-5555 (FNAL)
> +1-312-567-5745 (IIT)
> +1-630-888-0185/+44-(0)79-48-860-197 (US/UK mobile)
Re: runtime problem Andrew Johnson
RE: runtime problem Mark Rivers
runtime problem Pierrick Hanlet
Prev: RE: runtime problem Mark Rivers
Next: support for Cryomech CP950 compressor (part of PT405 cryorefrigerator) arvinder.palaha
Next: Re: runtime problem Andrew Johnson
