1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: dbreport or similar?
To: Andrew Johnson <[email protected]>, [email protected], Steve Kinder <[email protected]>
Date: Fri, 21 Apr 2017 13:41:28 -0400
On 04/21/2017 12:40 PM, Andrew Johnson wrote:
> Any modern scripting language should be able to extract record names and
> field values out of a DB file if you're OK with being fairly simplistic
> about it though (i.e. you don't care about expanding macros or include
> statements, or about checking record types and field values against the
> IOC's DBD file). The syntax is described in the Application Developers
> Guide Chapter 6 (Database Definition).
Steve,
https://github.com/epicsdeb/pypdb
FYI, includes a dbd parser using PLY.  As written, the 'getpvs' will
output a .po (translation) file with entries for each record name w/o
macros expansion.  Might be useful as a starting point.
dbreport or similar? Steve Kinder
Re: dbreport or similar? Andrew Johnson
Prev: Re: dbreport or similar? Andrew Johnson
Next: RE: Bandwidth limits in asyn Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Next: EPICS Archiver Appliance does not transfer PVs to "Being archived" Abdalla Ahmad
