1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Bandwidth limits in asyn
To: 'Iain Marcuson' <[email protected]>, "[email protected] >> EPICS Tech Talk" <[email protected]>
Date: Fri, 21 Apr 2017 17:46:18 +0000
If the diagnostics on each end don't solve the problem you may want to look at the network traffic with Wireshark.
-----Original Message-----
Sent: Friday, April 21, 2017 8:50 AM
To: Mark Rivers; [email protected] >> EPICS Tech Talk
I wrote a C program to read the data, and it also fails at about the same point.  The camera is a custom one, so I can put any diagnostics on it I want.
Iain.
> From: Mark Rivers [mailto:[email protected]]
> Sent: Thursday, April 20, 2017 5:17 PM
> To: Iain Marcuson <[email protected]>
> It does not sound to me like the error you are getting has anything to do with
> the fact that you are using asyn or EPICS.  Have you tried a simple C test
> program to read the data from the device?  It seems like a low-level
> communication problem.  What is the camera device on the other end of the
> wire?  Do you have access to any diagnostics on that end?
> Mark
> From: Iain Marcuson [mailto:[email protected]]
> Sent: Thursday, April 20, 2017 3:50 PM
> To: Mark Rivers
> I am using recv() on a socket opened in the constructor.  Recv() returns a -1
> and perror() says "Bad address".  In  the mockup server I made using Python,
> it reported "socket.error: [Errno 104] Connection reset by peer".
> Iain.
> > Sent: Thursday, April 20, 2017 4:47 PM
> > To: Iain Marcuson <[email protected]>; tech-
> > [email protected] >> EPICS Tech Talk <[email protected]>
> > What function does your readInt16Array function call to do the network
> > transfer?  Are you using the native socket calls, i.e. recv() or recvfrom()?
> > Are you using the EPICS osiSock.h to make your driver portable to
> > different OS?
> > When you say "the connection breaks" what exactly do you mean?  Is
> > recv() or recvfrom() returning 0 or a negative number?
> > Mark
> > Sent: Thursday, April 20, 2017 3:36 PM
> > I am calling my own asynPortDriver function with the readInt16Array
> > method.  This is 1 Gbit Ethernet.  On my most recent run, it took
> > 0.854 seconds to receive 19214960 bytes.
> > > Sent: Thursday, April 20, 2017 4:06 PM
> > > How are you reading the data, i.e. are you calling the drvAsynIPPort
> > > driver from your driver?
> > > If so, how have you called drvAsynIPPortConfigure?  What value are
> > > you specifying for the timeout?
> > > Is this 1 Gbit Ethernet?
> > > What is the time between when you start the transfer and it breaks
> > > after
> > > 17640000 bytes?
> > > Mark
> > > From: [email protected] [mailto:tech-talk-
> > > [email protected]] On Behalf Of Iain Marcuson
> > > Sent: Thursday, April 20, 2017 2:28 PM
> > > To: [email protected] >> EPICS Tech Talk
> > > Subject: Bandwidth limits in asyn
> > > I've been writing an asyn driver to receive data from a camera, but
> > > I seem to be hitting some sort of limit.  The total size to transmit
> > > is
> > > 35280000 bytes, but the connection breaks at around 17640000 bytes.
> > > In a mockup test, I was able to transfer all the data by sending 16k
> > > with a pause of 0.5 seconds between each packet.  The receiving
> > > routine just buffers all the incoming data until it reads the
> > > predetermined amount.  Is there something else I need to be doing to
> > > get
> > all the data?
> > > Thank you,
> > > Iain.
Bandwidth limits in asyn Iain Marcuson
RE: Bandwidth limits in asyn Mark Rivers
RE: Bandwidth limits in asyn Iain Marcuson
Prev: Re: dbreport or similar? Michael Davidsaver
Next: EPICS Archiver Appliance does not transfer PVs to "Being archived" Abdalla Ahmad
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Bandwidth limits in asyn Iain Marcuson
Next: dbreport or similar? Steve Kinder
