1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS Archiver Appliance does not transfer PVs to "Being archived"
To: "Abdalla Ahmad" <[email protected]>
Date: Mon, 24 Apr 2017 22:40:53 +0800 (GMT+08:00)
When I was deploying Archiver Appliance one month ago, I encountered the same issue and I finally found the root cause was that I brought up Archiver Appliance with non-root user, however, the default STS/MTS/LTS paths in the generated sampleStartup.sh script were as follows, which were not writable by non-root user without "chmod" configuration, thus Arcihver Appliance cannot create PB files. After setting STS/MTS/LTS path to a writable directory, the issue was gone and the state can transfer to "Being Archived".
export ARCHAPPL_SHORT_TERM_FOLDER=/arch/sts/ArchiverStore
export ARCHAPPL_MEDIUM_TERM_FOLDER=/arch/mts/ArchiverStore
export ARCHAPPL_LONG_TERM_FOLDER=/arch/lts/ArchiverStore
But I am not sure if your root cause is the same as mine.
Lin
-----Original Messages-----
Sent Time: Monday, April 24, 2017
Cc:
Subject: EPICS Archiver Appliance does not transfer PVs to "Being archived"
Hi
I used a single machine install for testing the archiver appliance as a proof-of-concept on a local machine. I added 2 PVs to the system using the management console, the status goes from "initial sampling" to "Appliance assigned" and it just stops here where it should go to "Being archived". Why the appliance is not archiving the PVs?
Thanks!
Abdalla.
RE: EPICS Archiver Appliance does not transfer PVs to "Being archived" Abdalla Ahmad
Prev: Re: EPICS Archiver Appliance does not transfer PVs to "Being archived" Michael Davidsaver
Next: Re: EPICS Archiver Appliance does not transfer PVs to "Being archived" Michael Davidsaver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: EPICS Archiver Appliance does not transfer PVs to "Being archived" Abdalla Ahmad
