On 04/26/2017 06:50 AM, Abdalla Ahmad wrote:
> Dear Michael
> Can you please elaborate more on installing the proxy you wrote? I'm having difficulties running it on Scientific Linux 7 machine.
> First I have the requirements (numpy, twisted and protocol-buffer), then I did:
> python setup.py build
> sudo python setup.py install
> After that I ran the command as in the README:
> twistd -n a2aproxy -P 8888 AA-SERVER-URL:17665
> And then I get "Wrong number of arguments".
oops, the README was wrong! '-A' is missing. Now fixed.
An known working example from nsls2 can be seen in
debian/channelarchiver-a2aproxy.default in the source tree.
> twistd a2aproxy -P 8889 -A http://capp01.cs.nsls2.local:17665/mgmt/bpl/getApplianceInfo -d
> Running "twistd a2aproxy" gives an error like "No module named EPICSEvent_pb2". Also when reordering the arguments it does not recognize the "-n" option.
twistd is picky about ordering of arguments as these are parsed by
different code. Arguments before the application name ('a2aproxy' in
this case) are for twisted itself (run 'twistd -h'). The remaining
arguments are for the application. (run 'twistd a2aproxy -h')
Switch to some other directory and retry.
By default python searches the current directory before /usr/local. I
would guess that, after installation, your shell is still in the source
directory, so 'import carchive' finds the copy in the source tree which
doesn't contain the generated files.
> python -c 'import carchive; print carchive.__file__'
Will show the path of the module which was imported.
- RE: EpicsQT and Archiver Appliance Abdalla Ahmad
Re: caRepeater not found when starting ioc under procServ Hinko Kocevar
<2017>
2025
2026
<2017>
2025
2026
