1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: caRepeater not found when starting ioc under procServ
To: Michael Westfall <[email protected]>, "[email protected] Talk" <[email protected]>
Date: Wed, 26 Apr 2017 18:35:00 +0000
Maybe using full path to the caRepeater would solve it?
Otherwise, I think using a config file that specifies the path and sourcing it in initd script might do the trick, too. As far as I know that is what any other initd script would do.
Hinko
On Wed, 26 Apr 2017 at 20:08, Michael Westfall <[email protected]> wrote:
Hello,
When I start my soft IOC under procserv using the procserv-initd script, the IOC reports that the caRepeater executable can't be located.
This is surely because the PATH variable is not set right in this case.
The question is how (or where) do you have to set the PATH variable for processes running under procServ using the procserv-initd script?
Thanks...
Mike Westfall
Control Systems Software Engineer
.. the more I see the less I believe.., AE AoR
Re: caRepeater not found when starting ioc under procServ Bruce Hill
caRepeater not found when starting ioc under procServ Michael Westfall
Prev: Re: EpicsQT and Archiver Appliance Michael Davidsaver
Next: Re: caRepeater not found when starting ioc under procServ Bruce Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: caRepeater not found when starting ioc under procServ Michael Westfall
