Subject: caRepeater not found when starting ioc under procServ
To: "[email protected] Talk" <[email protected]>
Date: Tue, 25 Apr 2017 18:08:03 -0300
Hello,
When I start my soft IOC under procserv using the procserv-initd script, the IOC reports that the caRepeater executable can't be located.
This is surely because the PATH variable is not set right in this case.
The question is how (or where) do you have to set the PATH variable for processes running under procServ using the procserv-initd script?
Thanks...
Mike Westfall
Control Systems Software Engineer
Re: caRepeater not found when starting ioc under procServ Hinko Kocevar
Prev: Re: dbCa::addAction pausing, 10000 channels to clear Pearson, Matthew R.
Next: RE: EPICS Archiver Appliance does not transfer PVs to "Being archived" Abdalla Ahmad
Next: Re: caRepeater not found when starting ioc under procServ Hinko Kocevar
