We avoid that problem by launching one procServ running caRepeater
on each host using the full path.
That way we don't rely on the ioc launching caRepeater and don't
lose caRepeater if the first ioc is down.
If you want to set PATH or other env for your ioc st.cmd you can do
it in the script that launches your procServ.
I'm not familiar w/ procserv-initd, but you could probably set PATH
there if you want. We launch our ioc's
from a custom /etc/init.d/ioc that sources other scripts to set
EPICS_CA* and other env vars.
- Bruce
On 4/26/2017 11:35 AM, Hinko Kocevar
wrote:
Maybe using full path to the caRepeater would solve it?
Otherwise, I think using a config file that specifies the
path and sourcing it in initd script might do the trick, too. As
far as I know that is what any other initd script would do.
Hinko
Hello,
When I start my soft IOC under procserv using the
procserv-initd script, the IOC reports that the
caRepeater executable can't be located.
This is surely because the PATH variable is not set right
in this case.
The question is how (or where) do you have to set
the PATH variable for processes running under
procServ using the procserv-initd script?
Thanks...
Mike Westfall
Control Systems Software Engineer
.. the more I see the less I
believe.., AE AoR
- Re: caRepeater not found when starting ioc under procServ Maren Purves
- Re: caRepeater not found when starting ioc under procServ Ralph Lange
- caRepeater not found when starting ioc under procServ Michael Westfall
- Re: caRepeater not found when starting ioc under procServ Hinko Kocevar
<2017>
2025
2026
<2017>
2025
2026
ANJ, 21 Dec 2017 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
